Front drive shaft question
Old Aug 10, 2010 | 10:03 PM
Busjoe's Avatar
I have a 93 w250. Upon inspection I found the double u joint or cardan joint way too loose. It looks like the center pivot ball is shot. I see there are u joints and a ball kit available for these. I have never been into one of these before. Are these easy to rebuild?
Old Aug 11, 2010 | 08:40 AM
dkimmel's Avatar
That type of shaft has a cv joint. They are a ***** to do, I send mine to a drive shaft shop. Then it's done.
Old Aug 11, 2010 | 10:08 AM
ofcmarc's Avatar
It isn't too bad to do. I rebuilt mine a couple years ago.
IIRC it comes apart opposite of the way you think it does.....
Old Aug 11, 2010 | 01:01 PM
Trebor's Avatar
Use a pointed punch to reference mark the original locations of the mating pieces before dismantling it if you decide on doing it yourself.
Old Aug 11, 2010 | 07:23 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Whenever I get joints put in a shaft I just give it to my local driveline shop and have them put em in. I hate doing U-joints.
Old Aug 12, 2010 | 09:16 PM
Free89W350's Avatar
Like ofc said it isn't that hard. The thing is is if the socket for the ball is shot you need another drive shaft because that is what helps keep it tight and aligned
Old Aug 12, 2010 | 09:42 PM
93 trucktor's Avatar
I have heard a persom can put 1410 yokes on the front axle and T/case front output, and build a normal front driveshaft without the c/v end on the driveline. I think this would work if you were not lifted high in the front. I am concidering this since my c/v is vibrating hardcore in 4x4. Plus getting maching yokes front/rear for easy trail repair.
Anyone else done this?? or heard of this???
Old Aug 12, 2010 | 11:34 PM
Busjoe's Avatar
I have looked at a few sites where the units have been rebuilt. It looks like if the ball and socket holder piece is in good shape the thing can be serviced. Im gona dive in soon. rockauto and napa among others have the pieces. By trade I work on much bigger stuff. These are kind of teeny but fun. I will let you know what I find...
Old Aug 12, 2010 | 11:48 PM
PapeCAT's Avatar
Yes Mieser has done this.
http://www.expeditionportal.com/foru...ghlight=meiser
He said there are no vibes.
But the problem is the Operating angles are somewhere in the vicinity of 13 degrees difference between front output and front axle yoke. Normal U joints need to have parallel yokes.... Factory setup is with CV and Chrysler has clocked our D60F to point the pinion straight at the T-Case stock. I put a '90 D60F under my '72 with Divorced NP205 and the lengthened / rebuilt stock CV is works really nice...
P1000491.jpg?t=1281675131
Old Aug 13, 2010 | 10:30 PM
DodgeMonkey's Avatar
mine was a beotch. I ended up cussing at if for a couple hours before I threw all the pieces in a box and took it to a driveline shop
Old Aug 14, 2010 | 10:01 AM
cougar's Avatar
Mine required cutting and rewelding to replace the ball.
93-331-29psi
Oct 19, 2013 12:05 PM
jhenson
Feb 21, 2009 07:19 AM
rob5182
Oct 25, 2008 10:47 AM
walexa
Jan 15, 2006 03:54 PM
bkay
Dec 12, 2002 05:22 PM
