front drive shaft question(s)
Old Jan 15, 2006 | 02:38 PM
walexa's Avatar
My truck started making a pop when in 4x4 and turning the wheels. I got a friend to stand outside the truck and locate where the popping is coming from, and he concluded it was the front drive shaft.......the one with the double cardan in it. Anyway, I removed it. All u-joints feel tight, but the splined section has a tiny bit of rotational slack to it. Is this joint supposed to be real tight, with the only movement being telescoping, or is a very small amount of rotational slack normal? Could this be causing the popping, or is it definitely my u-joints? I have the u-joints in hand, but since all joints "felt" tight, I wonder if something else is the culprit. Thanks in advance. By the way, the truck has almost 150k on it.
Waylan
Old Jan 15, 2006 | 03:44 PM
robert chilton's Avatar
That slack is wear and isnt supposed to be there. It can cause the noise you hear but I would check the Ujoints on the axle iteslf. My front shaft is worn like yours and I do not have any noise coming from it at almost 240k.
Old Jan 15, 2006 | 03:54 PM
smoke_pedal's Avatar
It's your front axle joints. Mine makes the same noise. they are expensive joints because they are so big.
93-331-29psi
Oct 19, 2013 12:05 PM
Busjoe
Aug 14, 2010 10:01 AM
jhenson
Feb 21, 2009 07:19 AM
rob5182
Oct 25, 2008 10:47 AM
bkay
Dec 12, 2002 05:22 PM
