Fluidamper install now no charge.
Old Sep 18, 2014 | 02:41 PM
  #46
sdseva's Avatar
double checked.. .4
Old Sep 18, 2014 | 02:44 PM
  #47
sdseva's Avatar
checked continuity for all three wires up to the pcm connector as well.. all three rang
Old Sep 18, 2014 | 02:59 PM
  #48
Angry Johnny's Avatar
You still have .4 with an additional wire? Unfortunately a continuity check may not tell the whole story on these old wiring harnesses.
Does the a/c compressor clutch engage? If you drive it does the o/d work?
Old Sep 18, 2014 | 04:18 PM
  #49
Try plugging in the PCM from your truck. If yours was originally a stick the o/d won't work but it should still charge.
Old Sep 18, 2014 | 05:08 PM
  #50
sdseva's Avatar
my pcm= no charge
Old Sep 18, 2014 | 05:43 PM
  #51
sdseva's Avatar
so does that mean its a break somewhere between the alt and the pcm?
Old Sep 18, 2014 | 07:33 PM
  #52
That is what it looks like. The green wire should be grounded by the pcm. Check the continuity from the alternator to the pcm
Old Sep 18, 2014 | 07:34 PM
  #53
Does the ac compressor clutch come on? Also does the O/D work? I ask these questions because it can point you/us in the right direction. If there is no CPS signal at the PCM, or it's not reading it then you won't have A/C, O/D or alternator charging. It's hard enough to diagnose stuff over the internet but without answering all the questions it makes it much harder and sends us all off in different directions. So please let us know if the A/C and O/D work.
Old Sep 18, 2014 | 08:22 PM
  #54
patdaly's Avatar
Yep, check your OD operation........
Johnny, does the first gen use the CPS sense to bring in the ASD relay like the second gen does?
Man, these are the times I wish I had a 92 or 93 service manual.
Old Sep 19, 2014 | 06:24 AM
  #55
The ASD should turn on for 3 seconds key on even if the engine isn't running. If it doesn't see the engine running it would then shut off. Once it sees the engine running it will turn it back on.
I wish I had a manual too, the only schematics I have access to don't show a CPS and have an external regulator. Pre 91.5 I'm guessing.
Old Sep 19, 2014 | 08:06 AM
  #56
patdaly's Avatar
Yea, pre-92........
Old Sep 19, 2014 | 12:07 PM
  #57
j_martin's Avatar
'93 diagrams here.
8W-1 to 8W-130 available
example url for 8W-18
http://i576.photobucket.com/albums/s...tics/8W-18.jpg
Run the link, then in your browser scrape off the "18" and put in the sheet number you want.
Old Sep 19, 2014 | 12:08 PM
  #58
Here's the wiring diagrams for a 93...
http://api.viglink.com/api/click?for...%20Photobucket
Old Sep 19, 2014 | 12:35 PM
  #59
sdseva's Avatar
I had to go to work and its been raining ever since! In san Diego! I still have to put everything back together before i can test drive it to check O/D and A/C. Ive never owned an automatic... How will I know if O/D works?
Old Sep 19, 2014 | 12:43 PM
  #60
sdseva's Avatar
I did try using the cps and pcm from my truck but.. my truck has an external VR. Probably due to a similar issue im guessing...?
