Fix your fuel cut-off solenoid
Old Jul 22, 2007 | 02:59 PM
  #61
thumbs's Avatar
Hi Dave
yeah when I shut the key off everything goes down but the engine. She just keeps on keepin on.
Now that being said I shot some wd up into the solenoid and the plunger and cleaned it up pretty well. There really wasn't much of a problem it was pretty clean. Oh the plunger always worked smoothly and easily. I cut those two connectors off and connected them with a ring connector and replaced it on the top of the solenoid. When I first started er up she ran a little funny but straightened herself out and ran fine. I took er on the road and she runs strong. I did some runnin around and shut er down 4 times without a problem. She also started without any problems. Maybe it was the connections or maybe just a tad of ***** in the solenoid but it seems to be fine.
Anyway the acid test is next week.
Old Jul 22, 2007 | 06:08 PM
  #62
MikeThomas's Avatar
Haha, pulled into work and my new plunger pooped out....arrrrrggggg
Old Jul 22, 2007 | 09:20 PM
  #63
dpuckett's Avatar
My solenoid is inop for now. I noticed it chugged and sputtered a lot (relatively, as it had a new pump from this spring, and injectors in May; fuel pressure is good at 7psi idle) when I started it this morning. I ran some errands, and brought it back home. Took a second after turning off the key for it to shut down. (It had been doing this intermittently for a few weeks now. I figured it was just an electircla gremlin). Got home this evening, and it wouldnt shut off. Could a piece of the rubber plunger have gotten broken off and into the pump internals? How bad is this? I wouldnt think rubber would affect 10K psi, but then again, the clearances are real tight in there.
Daniel
Old Jul 22, 2007 | 10:19 PM
  #64
MikeThomas's Avatar
Apparently the rubber does not cause any harm to us...Ive sent rubber through it twice now! Fortunately I was able to sand this one into shape cause the last one took such a large chunk that I could not fix it. Give this ol post a shot, you may luck out.
Old Jul 23, 2007 | 06:22 PM
  #65
dpuckett's Avatar
Originally Posted by MikeThomas
.... Give this ol post a shot, you may luck out.
I'll try that. I borrowed some wrenches, and will do it tonight. I just have to find a fuel return line for under $80 now....... Mine split in half over lunch hour.
DP
Old Jul 24, 2007 | 07:19 PM
  #66
You can patch it with hose. There's no pressure to speak of, and as long as your fix keeps air out the truck will run fine.
Old Jul 27, 2007 | 06:16 PM
  #67
thumbs's Avatar
Well just got back a couple of hours ago and after I took the plunger out and cleaned the solenoid and plunger not a problem in 700 miles. She ran, started and shutoff fine all week. Must have been just a bit of ***** in it.
Now for the age old question........how to get my egt's down.
Old Jul 27, 2007 | 07:01 PM
  #68
You need more air. Try a compressor upgrade.
Old Jul 27, 2007 | 07:13 PM
  #69
thumbs's Avatar
hi Wanadiesel
Yep I wrote ya just a minute or two ago. I think I'm ready to put one in. Where do ya get em and what kinda difference will it make? I can get 20 psi out of my setup now wot. I have plenty of peddle left I just run out of egt's. What do ya figure it will drop the egt's? Also will it whistle louder than the one I have in now?
Thanks
Old Jul 27, 2007 | 07:47 PM
  #70
dpuckett's Avatar
I tried finding a hose or adaptor to fit the metric fitting in the pump. No dice. I called the local Internation Truck dealer and they got it for me for $45, freight included.
DP
nailhead
Jul 21, 2006 08:41 AM
BC847
Mar 18, 2006 09:47 AM
Diesel-Dan
Apr 27, 2004 10:02 PM
1stGenBikeHauler
Jul 16, 2003 04:51 PM
1stGenBikeHauler
Jul 2, 2003 09:39 AM
