VW Fuel Cut Solenoid Worked!!
Old Jul 8, 2003 | 10:31 PM
1stGenBikeHauler's Avatar
<br> Well I just installed my VW fuel cut solenoid and <br>it worked like a champ. I called around and found one<br>for $35.58 out the door. (dodge dealer was over $200 )<br><br>It fits all VW and Audi diesels and the P/n is <br> [0 330 001 040 ]. I would suspect that it also works<br>in volvo diesels as well (its a VW motor with VE pump)<br>Since it is a bosch part I would iagine that there are<br>quite a few P/n's that are similar but that one might get <br>you headed in the right direction. So depending on what foreign car is the most popular in your area finding a cheap one should be simple.<br><br>The place I got it from was Valley Wagon in Carson City, NV.<br>Ph 775-882-2350. They ship daily so if you cant find one<br>look them up.<br><br><br><br><br><br><br><br><br><br><br>
Old Jul 9, 2003 | 02:17 AM
carl20320's Avatar
Re:VW Fuel Cut Solenoid Worked!!
Woo Hoooo!!
I just bought a VW VE injection pump off ebay for $10. I bought it to tear apart and learn how the darn thing works. Looks like there may be an even brighter side to it! 8)
Carl
Old Jul 9, 2003 | 07:04 AM
Craig93's Avatar
Excellent job 1st Gen.. 8)..that is a significant savings!
Old Jul 12, 2003 | 10:58 AM
Monty's Avatar
Thank you FirstGenBikeHauler! I have added your part number to the 1st gen section of the Tech Facts page. Let me know if any problems arise with your part. ;D Thanks again.
Old Jul 15, 2003 | 10:37 PM
Jim Shulmister's Avatar
Muted User
I have some bmw 524td's at the shop. They are 6 cyl turbodiesels with bosch ve pumps identicle to the cummins pump and they redline at over 5000rpm. I was trying to get the excentric cone out of one,but it doesnt want to pull all the way out for some reason. I also have some of the vw pumps on the shelf.<br> If i had a cummins ve in one hand and a bmw ve in the other, you wouldnt be able to tell me which was which.<br> -RATCHET-
Old Jul 16, 2003 | 04:51 PM
Monty's Avatar
Ratchet,<br><br>Try turning the eccentric 90 degrees or so and then trying to pull it out. Sometimes the fuel pin on the eccentric will not let it come out because of the depth of the cone and the bottom lip.
BC847
Jul 27, 2007 07:47 PM
nailhead
Jul 21, 2006 08:41 AM
BC847
Mar 18, 2006 09:47 AM
Diesel-Dan
Apr 27, 2004 10:02 PM
1stGenBikeHauler
Jul 2, 2003 09:39 AM
