finally gauges hooked up but a few ??
Old Jan 7, 2009 | 07:31 PM
STACKED's Avatar
ok finally done with the gauge install but i have a few problems and a few questions.
1. tranny temp in the hot line is around 200 just cruising at 10mph or so. is that right? it idles in neutral at 160 or more
2. fuel pressure is 0 all the time. ive checked for kinks and if i blow on it the gauge goes up. does the gauge have to be bled? i dont remember having to bleed the isspro on the 98.5. is the pump a gonner.
3. boost is 0 also and it will blow up it was stuck on 17 so i took it apart and there is a plastic connector that came loose so hooked it up and went back to 0. checked for kinks none. is the factory port on the intake manifold right under the boost elbo and grid heater a good spot?
4. EGTs are between 4-600 around 40mph. im sure thats ok. just checking this is my 1st, 1st gen
Old Jan 7, 2009 | 09:59 PM
gear jammer 91"'s Avatar
If your fuel pressure gauge is reading 0psi, I would guess that your lift pump is dead. Our injection pumps are capable of drawing there own fuel, so they will run with a dead lp.
I'm gonna guess that your boost gauge is always at 0, even if you floor it while driving? I have mine hooked up the same spot in the head and it works fine, so I would look for leaks in the line somewhere.
On the egt's, I was told that 100 degrees per 10mph is about how it should read cruising, (600 degrees at 60mph). That is of course with the probe pre turbo. With my pump turned up and my stock turbo my truck ran a little hotter than that while cruising.
I got nothing for your trans temp question though. Sorry.
Hope I was able to help ya out some.
Old Jan 7, 2009 | 10:42 PM
STACKED's Avatar
yeah thanks at 40mph should i see some boost with stock ex housing? i did blow the boost gauge up with a little blower hooked up to the compressor and it worked fine. im not sure what the deal is
if anyone could help me i was reading some back posts on the tranny temp and that 200 seems way to hot so is it where i have it hooked up in the OD spot, thts why its so hot or do i have some cross wires or what.
Old Jan 7, 2009 | 10:54 PM
Dean Snow's Avatar
My tranny temp runs right around 140 being easy on the pedal and around 160-190 average going on backish roads and up slight hills and stuff, just normal driving.
If I beat on it I can run it up to 260+ but I don't do that often. the tranny is a built transmission and nothing is wrong with it I'm almost certain
I'm tapped into my line right under my bed before it runs into my auxiliary trans cooler on the hot side.
Old Jan 8, 2009 | 01:34 PM
dstad's Avatar
260???????????????????????????? what the hell thats hot man
Old Jan 8, 2009 | 07:29 PM
Fergavs's Avatar
If your reading the hot/output of the trans then ya its gonna be hotter then if you get your reading from the pan. I dont remember my numbers but it is a big difference. The hot output is the temp of the fluid as it comes out of the converter. Those numbers dont sound to crazy for a non lock up converter. On my 47rh when I lock the converter my temp can drop as much as 30+ degrees.
Old Jan 8, 2009 | 08:26 PM
STACKED's Avatar
so what kind of numbers are ok with the sensor in the out line?
Old Jan 9, 2009 | 01:07 PM
bigragu's Avatar
Out line meaning tapping into the line at the most front of the transmission(hot line) and the most rear line coming from the coolers is the ATF return line(cool line). If this is what you are meaning, as a scenario, in CA temps now around noon are in the 50's and at cruising speen(60-70 mph) my temps are 150. As soon as I get into town w/ all the stop lights and such the temps climp up to 165. At a stop, I mean traffic backed up, my temps easily climp to 180. During the summer months I can expect to see an additional 15 to 20 degrees more at the given temps/scenarios. I, too have an aux. cooler/with fan that is being fed straight from the out line, goes through the aux. cooler, runs then to the cooler under the turbo, then to the finakl cooler by the front grill, then back to tranny. I pull my temps right as it comes out the hot line. I used to pull my temps from the pan, and the readings showed 15-20 degrees cooler.
Your boost guage will read next to nothing if you are cruising on flat road at a steady speed(around 5 psi). If you punch it going up a grade you should see anywhere(depending on your mods, with a single turbo) 18-30 psi. Check all intercooler boots, piping, etc. and possibly your intercooler for leaks if you cannot obtain these readings.
Your egt's sound correct.
Yiour fuel pressure, should read (I am using my readings as an example, and that is w/ the plunger lp) 15 psi steady and drop to around 10 psi at WOT. If I remember right, for stock lp, the readings are around 7 or 9 psi steady and 5 psi at WOT. Do not let your psi readings get at 3 and below psi on a stocker lp. Filter is clogged. At idle, if connected properly, your fuel pressure guage will have a reading. Make sure the negative wire is solo, and tied into the engine block somewhere(Autometer tech reccomendation). The solo negative mount also should fall for your pyrometer.
Old Jan 9, 2009 | 04:15 PM
STACKED's Avatar
well i finally got to take it for a good drive temps out side are around 70 so the trans says 230-250 all the time. i finally got it to boost if i punch it the boost hit about 17 it seems like it takes a lot to make these things boost.
the pyro seems to be working ok cruising at 60 it stays around 700-800.
bigragu for the grounds were u talking about the fuel pressure ground? i have a mechanical gauge. or all the gauges?
Old Jan 9, 2009 | 07:45 PM
Alwaysworking's Avatar
alwaysonDTR
if all you can get is 17 psi of boost there is a leak in the intercooler system, or the fuel screw has yet to be touched, or you trans is really shot
Old Jan 9, 2009 | 11:24 PM
bigragu's Avatar
So, with that, I am assuming that you do not have an isolator for the fuel or a snubber, correct? Who is the manufacturer for your guages? Either something(s) are not mechanically sound on your truck or you have faulty guages. Boost should be much higher, trans temp should only be at your temps hardly ever(better yet, NEVER) and your pyro, well, is working OK. So the questions are:
1. What type of guages?
2. did you use thread sealants on your boost guage fittings?
3. Are your intake system components snug and leak free?
4. Where are you pullin' your tranny temps from? Have you serviced the transmission lately?
Old Jan 9, 2009 | 11:29 PM
alwaysonDTR
if there is air in the fuel line the pressure gauge will not work
Old Jan 10, 2009 | 12:51 PM
STACKED's Avatar
Would no fuel pressure cause low boost? I have Autometer gauges and I did use thread tape I need to check for leaks and the trans temp is in the hot line where the OD sensor used to be. How do I get the air out of the line?
Old Jan 10, 2009 | 01:16 PM
alwaysonDTR
yes no FP could cause low boost, because theres no fuel to make boost, to get the air out of the line you'd have to loosen it and leek the air out thats ho i would do, but OUT OF THE CAB of course.
another thing with thread tape it can get into the lines and plug things up
ARbowhunter7
Jul 4, 2011 04:06 PM
FishBio31
Jun 21, 2010 09:48 PM
coontz0473
17
Sep 22, 2006 03:52 PM
sandpuller2004
Mar 8, 2006 10:13 AM
03CTDCO
Feb 27, 2005 07:30 PM
