Fan removal tools
Old Jul 1, 2009 | 07:17 AM
Featherman's Avatar
Fan removal tools
What have you guys used to remove/replace the fan in one of these trucks? Where would you buy the tool(s)? Looks like one would need a very "Skinny wrench"
Thanks,
Old Jul 1, 2009 | 07:40 AM
ofcmarc's Avatar
Fan hub wrench from Napa or the like along with a hammer.
Old Jul 1, 2009 | 08:07 AM
BC847's Avatar
1st Generation Admin
Anti-seize for the threads.
Old Jul 1, 2009 | 08:19 AM
John Faughn's Avatar
There are several types out there , I would recomend getting the correct tool to avoid issues , usually they have backwards threads [ I can not say I have worked on every yr / model ] , best is to look at the blades of the fan & figure which way it turns , when running , then to take off , turn in the opposite direction on normal running .
It takes 2 large flat wrenches , one goes around the nut , the other is big enough to go around the nuts that bolt the pulley on [ as if it were a nut ] .
Do not let them sell you the universal tool that pivots like a scissors , just slips off too easy , many have used a hammer & chisel , well that may work in a pinch , but creates all kinds of future problems .
Old Jul 1, 2009 | 10:59 AM
Thunderhog's Avatar
I went to the cheap-o tool store and bought an SAE whench that was close (the fan is Metic) then just ground it to fit. Cost me 3.00. I cannot remember the size I bought, but can check after work. I guess I am just cheap.
Old Jul 1, 2009 | 06:01 PM
BearKiller's Avatar
I welded up my own from flat steel stock.
I just used the big nut on the fan-clutch as a pattern and made the wrench fit.
I also made a "holder" wrench that catches the bolt-heads and holds the pulley still.
I actually have better success by sharply striking the END of the wrench,while holding pressure in the direction of removal.
All I have ever messed with are threaded contrary to standard direction.
Use plenty of anti-sieze.
thejoker502
Apr 6, 2010 10:56 PM
ted_pulliam
17
Dec 20, 2009 12:39 AM
buckman361
Mar 7, 2008 10:44 PM
big jimmy
Jul 7, 2006 01:33 PM
kawi600
Jan 26, 2006 10:19 AM
