Exhaust housing
Exhaust housing
I've got the #16 housing on but when I hit the long grades pulling my 5, er it hit's 900* rather fast. the pump has been turned up 10% and I'm running the power-wagon injectors. The timming also has been increasted. I have a 3" down pipe to a 4' exhaust with a new aro muffler that's supposed to help with fuel milage and exhaust temp. The muffler seems to help on exhaust temp but I want to know if putting the 18.5 houseing back on would help lower the exhaust temp more.. Thanks... Ralph...
where is your pyro probe? 900 is nothing as long as it is pre turbo. the 18.5 with most likly make it run hotter as it lags to spin the air the air out of there. i would ditch the air box as well.
jiMMy
jiMMy
Unless you are running at high RPM's, say 2400+ putting the bigger housing on will make things worse, not better.
If you are running down around 1700 RPM, then going even smaller might help.
My understanding is you would need to be pushing well over 300hp before the 16 would get restrictive . . .
Depending on the grade that you are pulling, the weight of your 5'er and the rear end axle ratio those readings may be the best that you can expect, but you would definitely want to see them less than that. If you are using 5th gear and the temperature is moving up then shift down to 4th gear - that may help.
I have watched this for some time. The 12 valvers run 21, 18, and usually the smallest the 16. The 24 valves come stock with 12. Why would not the 12 valve run just fine with a 12w.
Originally posted by jiMMyCTD
can you tow anythign with a 12cm?
jiMMy
jiMMy
During the summer I pull a 4000# Jeep behind with a 2000# camper on the truck. Never have had an issue with EGTs on the 12cm.
if you do end up getting a 12cm housing and would like to unload your 16 for cheap i would be interested also, if you want an 18.5 i would be willing to trade, i just need something to hold me off until i save up the money for the pdr 35
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
HOHN
Dec 7, 2003 02:07 PM
dart440_72
Jul 10, 2003 08:00 PM
