Engine died and wont start back up! Need help!
Old Dec 4, 2009 | 12:02 AM
93-12Smoke's Avatar
First off I know this is about a 4bt and I have posted on that site as well but thought I would take advise from yall as well. I installed my 4bt into my Toyota pickup. It ran fine in the truck for about 2-3 hrs. Took it for a drive today and after about 15 min. it just died and wont crank back up. When I say it died it just lost RPM's until it died, but still turns over fine. I have power to the injector pump and the fuel filter is still full of fuel as well as the lines to the lift pump and on to the fuel filter. I opened an injector line and pumped the lift pump and got no flow. I also cracked the line from the lift pump to the filter and got no change in pressure of what was leaking out when I originally crakced the line. There also seems to be no resistance on the manual pump when compared to my 12 valve. Question is if the lift pump dies will it cause the engins to just die.
Old Dec 4, 2009 | 06:02 AM
jogl's Avatar
The answer to your question is sometimes.
If you crack the fuel line from the lift pump to the filter, and then crank the engine over, a lot of fuel should come out.
JP.
Old Dec 4, 2009 | 06:04 AM
Field_boss_cb's Avatar
The fuel pump can cause it to die. What is the temperture where live, could it be jelled fuel?
Old Dec 4, 2009 | 06:13 AM
ebteckx's Avatar
if there is no resistance on the lever try bumping the key and then pumping to see if that changes. if not its very possible you have a frozen lift pump. That actually happened to me a few weeks ago on my truck. Died pulling up to a stop light blasted pump seized right up.... luckily in the up position didnt damage the cam...
Old Dec 4, 2009 | 08:45 AM
93-12Smoke's Avatar
It was in the 40's today but the fuel flowed fine from the line when I pulled it loose.
Old Dec 4, 2009 | 09:18 AM
patdaly's Avatar
Pull the plunger out of the fuel control solenoid, and put just the housing back, see if it starts. If it does, the solenoid burnt out, not a big thing. You can either run it from the manual shutoff or replace the solenoid.
Old Dec 4, 2009 | 03:37 PM
93-12Smoke's Avatar
Removed the plunger and still nothing. Opened the line from the lift pump to the filter and pumped the manual lever and got no fuel spray. Just replaced the lift pump and am waiting on the battery to charge back up to try it again. Left the dang key on when I went to the parts store and ate lunch
Old Dec 5, 2009 | 06:25 AM
ebteckx's Avatar
Id like to see pictures of that yota if you got em. Checking your gallery now...
Old Dec 5, 2009 | 08:21 AM
93-12Smoke's Avatar
Lift pump fixed it, Thanks for yalls help.
Old Dec 5, 2009 | 08:38 AM
93-12Smoke's Avatar
Heres two pics. We are working on leveling the front since the diesel was a wee bit heavier than the first motor. Also making some bumpers.
Attached Thumbnails Engine died and wont start back up! Need help!-warrens-truck.jpg   Engine died and wont start back up! Need help!-warrens-truck2.jpg
Old Dec 6, 2009 | 10:42 PM
ebteckx's Avatar
Dude thats pretty cool. Whats the other monster in the background?
Old Dec 8, 2009 | 02:21 AM
93-12Smoke's Avatar
The one in the back ground is my brother in laws 70 something Ford with a 429, 2.5 ton Rockwells and cut 52'' military tires. The 4dr Ford is my father in laws 70 something with 2.5 tons and 60'' tractor tires and a 460. Also included a little pic of the Ford having to pull the my father in laws 12 valve out. Apparently 30,000+ lbs is to much for even the 12valve off road. I tried to keep the weight down on my truck as both of thiers tip the scales at around 10,000 LBS.
Attached Thumbnails Engine died and wont start back up! Need help!-brad-chris.jpg   Engine died and wont start back up! Need help!-chris-stuck.jpg
RyanF
Dec 21, 2008 03:07 AM
grdnw523
Apr 23, 2007 12:23 AM
cumingetsome98
Mar 11, 2006 02:48 PM
russbond
Dec 17, 2005 01:44 PM
smokNjoe
Aug 1, 2005 11:16 AM
