Electrical question
Old May 23, 2017 | 02:52 PM
Dan s's Avatar
Electrical question
Can someone tell me what each of these do. The plug to the steering column and also short out the MAXI fuse The one that is totally burnt used to be blue. Yes I was lucky the truck didn't burn.
Old May 23, 2017 | 05:35 PM
Don't have a 1990 FSM so Going to guess that it's the wiring to the headlight switch.
Old May 23, 2017 | 06:26 PM
Dan s's Avatar
Sorry but no. It goes to the ignition switch. I've figured out that the blue wire runs the fuel shut off switch but I'm not sure what else. The only way I know this is because I fired the truck up and cut it and truck shut down. If someone knows more please let me know. Thanks tcows for your support nput
Old May 23, 2017 | 07:01 PM
Here Ya go Dan.....did a little google searching a found this....
https://www.dieselbombers.com/1st-ge...-diagrams.html
Hope it has what you need.
Old May 24, 2017 | 09:41 PM
j_martin's Avatar
As I remember, the blue wire provides 12v to these and maybe others.
Fuel shut off valve
Intake heater solenoids
OD solenoid
As you can see it runs behind linkages and past hot things. The only fuse to it is the fusible link. Shorts in that circuit are common.
AggiePhil
19
Feb 9, 2005 07:53 PM
apache
Sep 22, 2004 10:48 AM
schorb
Aug 19, 2004 08:25 AM
tool
Feb 7, 2004 12:25 AM
White02Sport
Oct 6, 2002 07:11 PM
