Dynoed today!
Old Oct 21, 2007 | 07:43 PM
Talking Dynoed today!
The numbers are in my sig. Many thanks to SteamDave and Wes Dimig for their help jumping the timing gears on Saturday. We put the truck at TDC and set the indicator to zero, then jumped the gear a tooth and moved the pump to get the indicator back on zero to give me a baseline. I wouldn't have believed it if I wasn't there, but with the timing set back where it was and the gear jumped a tooth, the stock timing marks line right up. So now my truck looks like it has an 1/8" bump. Wes is a Cummins tech, he cleaned up my timing cover and installed the seals and gasket like they do at Cummins - no leaks!
I dynoed this morning. The KSB was hotwired for 2 of the 3 runs. I did a 3rd water/meth run with the KSB disconnected and lost 34 HP and 12 ft/lbs. I think it's time to start looking at case pressure...
Old Oct 21, 2007 | 07:45 PM
mikmaze's Avatar
wow, nice numbers Dave, never would have guessed lookin at it, sure hate to pull along side you at a lite.
Old Oct 21, 2007 | 07:53 PM
Ha. With that automatic you'd be 6 lengths ahead before I got it into 3rd.
Old Oct 21, 2007 | 07:58 PM
BC847's Avatar
1st Generation Admin
Those are some big numbers there Dave.
So, . . . . . how big are those EDM's?
Old Oct 21, 2007 | 09:47 PM
Boatnik's Avatar
Good Job to all. I am insanely jealous.
Old Oct 21, 2007 | 10:10 PM
loch's Avatar
Very nice Dave, i'll pull along side you any day, yours might make mine look better.
Old Oct 21, 2007 | 10:25 PM
bgilbert's Avatar
Good numbers Dave. With all these new dyno numbers, I better get to work on my twins!
Old Oct 22, 2007 | 05:57 AM
JD730's Avatar
6x16's, Same ones I put in on saturday and lost almost 40hp with no other changes. ran 370.12/836.70 with POD's, swapped out the injectors and ran again. 332.66/771.30
Dave's at least happy, but now I'm definitely disappointed.
Like Dave said, I think case pressure has to be looked at and maybe some external help.
I'm the one you want to watch out for at a light.
Old Oct 22, 2007 | 10:10 AM
ruquik's Avatar
Dave figured out that my truck had the key in the off position, and there-by was the result of the extremely poor dyno numbers.
Old Oct 22, 2007 | 03:21 PM
Too big for a piston lift pump. I think my Walbro setup needs to be upgraded to keep all the fuel from draining out of the VE when the pedal is mashed.
I was very disappointed with Mike's numbers, I was expecting more out of his truck since he has a decent turbo.
Old Oct 22, 2007 | 05:28 PM
SmokemS's Avatar
wish i would of been there to watch those numbers dave to bad i was late....but thanks for your help with the brake line......you are one of the most helpful guys i know ......great numbers
ps i want my numbers to be right were you are
Old Oct 22, 2007 | 06:07 PM
gman07's Avatar
I look forward to a fully documented write-up with images before too long
Great numbers!
Old Oct 22, 2007 | 06:48 PM
G1625S's Avatar
Great numbers!
My writeups aren't worth a darn, but my spare AFC top is tapped for an additional fuel inlet and pressure gauge. Once I get the gauge plumbed in, ya'll get videos of what's going on when a VE starves
edit--good #'s Dave! Must be rough having a 400 RWHP daily driver
edit-edit----did you do the timing with the factory tool? If so, where is it set at compared to your old setting, and, can you feel a difference like what I described?
Thanks!
greg
Old Oct 22, 2007 | 11:55 PM
GLHS's Avatar
Good job Dave!
When are you getting a bigger turbo?
Old Oct 23, 2007 | 10:10 AM
ruquik's Avatar
Dave, I called up SGS regarding the horrible pull. The guy on the phone said he would talk it over with the guys and they would see about letting me get a free pull spring fling.
What a bunch of crap. I'm the one that got short changed. I guess I need to talk to Andy or someone on the site that has some pull up there.
