dual diaphram vacuum assist
Old Aug 31, 2008 | 03:16 PM
kraken's Avatar
Iv'e got a problem. Iv'e got an '89 D-250 and I dont really get how the vacuum system really works. It looks like there are two vacuum pumps that run off the power steering to assist the power booster for the brake master cylinder. Is this correct???? And if so how do I determine if my booster is bad or the vacuum pumps are bad???
Old Aug 31, 2008 | 04:46 PM
The two pumps are plumbed in parallel to provide more pumping capacity. They supply vacuum for the brake booster, HVAC system, and cruise control. To test the pumps, pull the line off the pumps and hook up a vacuum gauge. As long as you get 8.5" they are within spec, most of them will pull around 20" though.
To test the booster, use a Mityvac or similar hand pump and see if you can pump the booster down. If you can't pull a vacuum on it, it's bad.
Old Sep 1, 2008 | 04:03 PM
kraken's Avatar
Thanks alot I'll give that a try!
2mtrucks
Aug 22, 2014 10:30 PM
BearKiller
Jul 27, 2007 05:15 PM
mr T
Aug 11, 2006 08:01 PM
BearKiller
Jan 29, 2006 08:24 AM
crossy
19
Apr 16, 2005 09:51 PM
