vacuum assist problems - test results
Old Aug 11, 2006 | 05:53 PM
mr T's Avatar
ok..changed the rear shoes...and added the bigger chev wheel cylinders...if i slam the brakes this truck stops like a car!!...however if im screwing around in a parking lot or if im standign at the lights holding the brakes i still loose vacuum and the pedal gets hard....now i know this is normal to a degree on this year of truck and the solution is the vacuum reservoir ...i tried that and helped very little...and i never used to get this problem before..it started about a month ago ...first thing i did is trace all the lines and tightened the connections everywhere...transfer case..front axle...the works....
so we finally hooked up the gauge...on the main hose running to the booster i get 27psi idle...on one of the little lines i get 27psi idle...i press the pedal 2 1/2 times and im down to zero...27-15-5-nothing...then it takes 10 sec to come back
i am now suspecting that the booster itself is gone and one of the diaphragms is toast or something
what do u guys think?
Old Aug 11, 2006 | 07:50 PM
RCW's Avatar
RCW
It does sound like a failed diaphram or the actuator valve, which is built into the entire unit that should be replaced.
Old Aug 11, 2006 | 08:01 PM
mr T's Avatar
yeah i did searches on this thing and been reading alot ...i remember u had an old post somewhere...i found one at advance 75$....subsract 20 if i give em the core....fair price??
Rocket99
Feb 3, 2014 01:49 PM
CascadeFirstGen
Sep 19, 2013 08:38 AM
prattman
Mar 17, 2011 05:03 PM
kraken
Sep 1, 2008 04:03 PM
crossy
19
Apr 16, 2005 09:51 PM
