dowel pin
dowel pin
I called TST products to order a dowel pin kit. They said I didn't need one and
he also said that the 89-93s didn't have that problem. , is this true? I'll be able to reed your replies but not respond...Work
Thanks
Thanks
Not true. my 1990 dowl pin at or near 300K was just about to fall out! its a cheep fix not to have peace of mind .all you need to do is pull the cover and use a punch to push the pin back in, if it has moved ,and then use a ball peen hammer and round over the hole the pin will never come out and the gear case can still be removed a seal and gasket cost $50, and you can sleep at night.there are all kinds of ways to tab that pin its your choise on how
good luck.
good luck.
Crimedog
01-20-2004 12:40 AM
Rocket95
06-14-2003 02:27 PM
