difference in turbos
Old May 13, 2006 | 10:02 AM
0629doug's Avatar
what do i gain by by changing the turbo and housing and should i go with a waste gate style. just use it pulling work trailer around 7000 lbs. It is intercooled. also where would i find gauges and tach for this year truck.
Old May 13, 2006 | 10:13 AM
jeepsuck's Avatar
i think you gain turbo response and/or boost pressure. although i think you usually give one up for the other. someone who knows should speak up.
Old May 13, 2006 | 12:43 PM
Doug, give us a little more info. What trans do you have? What do you plan to do with the truck?
Old May 14, 2006 | 10:03 AM
Falcon1's Avatar
Ya what he said!
Old May 14, 2006 | 10:20 AM
OK, I see you edited the first post. One more question: Is the truck intercooled? A non-intercooled truck has an 18.5 cm housing that works pretty well with an automatic and a tweaked pump, there's really not much to be gained in that case. If you want faster spoolup for better response around town, a 12 cm wastegated housing will do that, and used ones are cheap enough that it's worth doing. The 16 cm housing is not enough of an improvement on an automatic to justify the price.
The early intercooled trucks have the completely worthless 21 cm housing, which you should ditch now if not sooner. Those take nearly forever to spool and don't provide enough boost to control EGT once they are spooled. In this case the 16 cm housing is a good improvement for the price. The 12 cm is also a good option here, especially if the truck spends most of its time in town.
dditt0635004x4
13
Feb 7, 2007 12:36 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
jrs_dodge_diesel
13
Dec 22, 2003 09:50 PM
1320
30
May 31, 2003 01:01 AM
