Difference in injection pums
Old Sep 29, 2011 | 09:32 AM
DPFservice's Avatar
I am about to replace my pump and was wondering if there was a difference in pumps between industrial, marine, and our application? Thanks
Old Sep 29, 2011 | 01:11 PM
Yes there is. Most Industrial, and Marine applications don't have a proper AFC set-up. Since most are designed to run full throttle and no load variation. So if you were to get one you would need to swap over your top off your IP in your truck. I think the rest is basicly the same...but look closely before your buy since some marine/industrial IP are oriented differnetly and some times have things switched around from side to side.
Old Sep 29, 2011 | 07:21 PM
dieselJon's Avatar
Our Dodge Cummins are the only one with a 12mm head and rotor in the VE. Most others are 9 and 10mm. Meaning, less power.
Old Sep 30, 2011 | 12:32 AM
DPFservice's Avatar
This is the info I was looking for. Thanks
Old Sep 30, 2011 | 10:29 PM
roxxx's Avatar
what about the Ve motors that were in the emergency vehicles, didn't they have 215 hp and were Ve ?
CMN_NOT_STROKN
Nov 22, 2024 02:55 PM
tommurray
Feb 23, 2014 10:38 AM
dieselman83
Sep 23, 2008 11:36 PM
j_k_auto
Aug 8, 2007 10:14 AM
jet
Nov 16, 2002 09:32 PM
