94-96 & 96-98 injection pump & engine difference?
Old Aug 2, 2007 | 03:41 PM
j_k_auto's Avatar
I would like to start off with saying hello all.
I was wondering if I get a 94-95 engine what would it take to make it a 97-98?
Since it is hard for me to find this I might of found a 94-95 engine. I would like to update it to the 215 hp style. What would it take?
Thanks Joe
Old Aug 2, 2007 | 03:59 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
You will need a 215hp pump and 215 injectors.'94-'95 had either 160,175 and 180 pumps depending on trans.
Old Aug 2, 2007 | 04:01 PM
logskidder's Avatar
Where are you in Pa?? The only major difference between the engines would be the injector pump. The 94-95 Dodges use 160-175 pumps and the 96-98 use the 180-215 pumps. The 160-175 pumps are sometimes looked down on, however a good fuel tune can see over 450HP with the smaller pumps. If you still want a 94-95 to 215 spec's you will need a injector pump off a 96-98 5sp.
Old Aug 2, 2007 | 04:04 PM
logskidder's Avatar
Forgot about the injectors....not much talk about stock injectors these days.
Old Aug 2, 2007 | 04:24 PM
j_k_auto's Avatar
logskidder
Pm sent to you
Old Aug 2, 2007 | 04:26 PM
j_k_auto's Avatar
Ok I was told that the piston rings were moved down on the piston after 96. would this concern you? if so why did they do this?
Old Aug 2, 2007 | 08:18 PM
logskidder's Avatar
They lowered the rings in the bigger pumped engines to reduce stress cracks in the crowns......its not something you should worry about.
Old Aug 2, 2007 | 10:28 PM
ckt_santiago's Avatar
If you are swapping pumps for a bigger one would you be willing to sell me your smaller pump for the same price as the core charge? My truck smoked the pump about three weeks ago and I need it to get to and from work... The fuel costs from my fiancé going so far out of her way to take me to work are killing us As a disabled veteran I don't even have the $725 for a Pensacola Diesel rebuilt
PM me if you can help me
Old Aug 8, 2007 | 12:39 AM
j_k_auto's Avatar
Well I am not sure what to say to this. I got a 97 6bt and going to put it in.
I do fell your pain but I am not sure where this would help me.
Joe
Old Aug 8, 2007 | 10:14 AM
Gearjammer's Avatar
If you live in PA give Diesel injection of Pittsburgh a call (Pittsburgh power).These guys are Cummins specialists.They have been building big horsepower Cummins for 30 years.
305motorsgt
Apr 27, 2014 08:17 AM
tommurray
Feb 23, 2014 10:38 AM
DPFservice
Sep 30, 2011 10:29 PM
yamarx1
Feb 13, 2009 10:37 AM
dieselman83
Sep 23, 2008 11:36 PM
