Dana 70 axle seal from Fel pro. # 55328
Old Sep 27, 2019 | 08:57 AM
Been using these for a while. Much nicer than the form a gasket goop, and they seal nicely.
One time use, but no scraping and they're not very expensive. I keep a half,dozen or or so in stock.
Fel pro axle gasket 55328
Old Sep 27, 2019 | 12:05 PM
Alec's Avatar
They're like the OEM coated metal gaskets?
Old Sep 27, 2019 | 03:40 PM
Absolutely correct.
Fel pro makes a couple different versions, but this one is embossed. What happens is when you clamp down on the bolts (Torque to spec or whatever you're comfortable with) the embossed part flattens out. I've used these for about 10 years, and never have they leaked. They're so easy as well, as they just fall off, wipe down the surfaces, and install a new one.
They're only good for one shot, but for a couple of dollars, it's well worth not having to deal with that goop.
here's the linky from Amazon:
Amazon Amazon
Old Sep 27, 2019 | 04:32 PM
Just searched these on Canadian Amazon...$10 each!!
Old Sep 27, 2019 | 04:35 PM
Why are they so much more? Is it a tariff or the distance?
500% is a big markup
Old Sep 27, 2019 | 07:51 PM
Welcome to buying parts in Canada....just the way it is, sure it has to do with taxes and tariffs but costs of parts are usually a minimum 50% more up here. I priced out some tune up and servicing parts for my daughter 02 Neon, through Rockauto was around $250 Cnd, local parts shop wanted over $700 for the same parts!
Old Sep 27, 2019 | 08:23 PM
My god....
That's insane. I get the idea that you live in God's country, but that's a heck of a price to pay for being so lucky to live where you do.
Let's hope the new trade deal goes through, and you (Canada) benefits from it.
Again.
Why?
What causes this economic burden upon the fine people of Canada? Corrupt politicians like we have here? Or is there some other factor guiding this ?
Old Sep 27, 2019 | 09:11 PM
edwinsmith's Avatar
Originally Posted by NJTman
Absolutely correct.
here's the linky from Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When I clicked the link, Amazon said it doesn't fit my 89 D350. Does FelPro make one to fit?
Old Sep 27, 2019 | 09:33 PM
Fwiw it says the same for my truck....that it doesn't fit.
A decade of use on my ride says differently.
Old Sep 28, 2019 | 12:32 AM
If it's a Dana 70 then it will fit....might be the same for Dana 60 and 80 as well??
Old Sep 28, 2019 | 06:41 AM
Gunch's Avatar
5 Year Member
Good info always used Rtv never bothered checking for gaskets .But for less than 3$ apiece I’ll b ordering some for sure
Old Sep 28, 2019 | 07:55 AM
Make sure both mating surfaces are spickey span clean.
After that initial cleaning, all you'll ever have to do is wipe it diwn, a little brake cleaner and slap it together.
Old Sep 28, 2019 | 04:28 PM
edwinsmith's Avatar
Are you trying to say that Amazon is wrong?
That's great to hear! I'll get a couple for my next job.
Edwin
rtroyer88
Nov 11, 2018 07:44 PM
GIT-R-DONE
Aug 17, 2017 10:47 PM
tator
Jun 30, 2009 12:01 PM
big stinky
Jun 11, 2008 06:56 PM
DODGE4X4
Sep 9, 2003 11:16 AM
