P/N help
P/N help
I tried using that wiki thing, but cant find what Im looking for. I need part numbers for the rear axle seal and bearing/race for my trucks dana 80. Axle seal is leaking, so I figured I may as well replace the bearing too. Even the local parts store couldnt find the right one.
FWIW the old sticky in the beginning of each forum was alot easier than that other thing is (or I dont know how to use it )
Don't readily know the part numbers but when you say axle seal are we to assume axle wheel seal or pinion seal? Also whether this is an axle from a 2500 or a 3500 truck, the 2500 truck uses a dana 80 hybrid axle. It's part dana 80 and part dana 70 and would utilize different bearings and seals.
If it's a wheel seal I wouldn't just replace the bearing because you are in their. It should be in an oil bath and likley in perfectly functioning condition.
2500TurboDodge
07-31-2006 04:21 PM
