dana 60 pinion nut size
Old Jul 15, 2009 | 08:07 PM
1985cucv's Avatar
ok so i tried taking off the pinion nut on the dana 60 and i cannot find the right size. i know it is 1 5/16 however the socket will not fit in deep enough to get the nut out because the yoke is in the way. i was using a 3/4 inch drive would a half inch be any different if it isnt im stumped. thanks
Old Jul 15, 2009 | 08:42 PM
sdstriper's Avatar
2 9/16" Iirc. And thats a thin wall socket too...
Old Jul 15, 2009 | 09:12 PM
1985cucv's Avatar
where do i get that from?
Old Jul 15, 2009 | 10:12 PM
BearKiller's Avatar
Last one I messed with was 2-5/16, or maybe it was 1-5/16, if I remember correctly.
Old Jul 15, 2009 | 11:15 PM
CaptainChrysler's Avatar
I think he was talking about the wheel bearing nuts.
The pinion is a 1-5/16". You need a thin wall socket to get it with a ratchet.
I have had luck using the common 3/4" setup and pushing in really hard while blasting it with the impact.
Old Jul 16, 2009 | 01:45 PM
sdstriper's Avatar
I'll correct myself when I confirm the socket I have. It's 60 miles away in a buddies shop right now...
Old Jul 16, 2009 | 04:50 PM
bgilbert's Avatar
Can you grind the socket some for it to fit?
Old Jul 16, 2009 | 05:27 PM
1985cucv's Avatar
not my socket i ordered the right one 1 5/16 thin wall thanks guys
Old Jul 16, 2009 | 10:49 PM
jimlj's Avatar
The 1 5/16 socket from NAPA's 3/4 drive Evercraft socket set will fit. I ended up buying the whole set but my local store offered to sell me the socket only for about $15.
ATEAV8GN
18
Jan 24, 2018 12:28 PM
Ramdriver15
Oct 29, 2008 08:45 AM
Purplezr2
Dec 3, 2007 09:59 AM
CTD NUT
Mar 8, 2005 08:32 AM
ATEAV8GN
Jan 13, 2003 03:24 PM
