Cruize Control failure
I just bought another 92 CTD.
The cruize does not work.
The speedo works, the cable is hooked up and has not slipped. the cable feels attached on the control unit end.
the fuses are all good,
What should I check next.
Any advise would be apriciated. Thanks
Frosty
Frosty
Re:Cruize Control failure
Same deal when I bought mine, pulled the cover off the wheel to expose the switches and checked for power in and out. Turns out the "set" microswitch was bad on mine, replaced it, haven't had a prob since.
I hope you have better luck solving your problem than I have had. I have tested everything I can think of ... switches, wiring harness, clock spring, all the test procedures in the manual. The only thing I have not done is rent an OBD II tester and see if it gives me any fault codes. I guess that is the next step.
Carl
Carl
Thanks again.
Fortunately I have two 92s now The one has cruze that works like a champ. If I have any problems I can check the one that works and compare readings to the one that doesnt work.
Frosty
Frosty
CC troubleshooting revisited
Originally Posted by ;329597
Also check your brake light switch that is located on the back side of the brake pedal. The cruise will not work if the switch is bad.
Inquiring minds (ie me
) want to know of the CC fixes. I, like carl have checked everything and still can't figure this thing out
. I'm guessing my brake switch works but you never know
Mountaineer
Oct 4, 2011 07:00 PM
