Cruise control....
Not trying to hijack this thread, but my cruise control quit working yesterday. Does the cruise work strictly off vacuum? Does the cruise switch on the steering wheel send an electrical signal to the diaphragm? I'm just trying to get a handle on how it works so I can troubleshoot it.
Check the fuse, Check for power at the switches,
I belive theres something called a clockspring in your column that may have went bad.
Just wait till you've had a clockspring go BOING and tangle itself up, and then you get to fight the wheel! It's a bit harrowing at speed.
Could a pseudo-VSS signal be obtained from a tach pickup on the alternator, as was used with the old AutoMeter tach kits? The pickup was similar to the pickups used for recording conversations from your telephone(just a 500-ohm coil with a suction cup) which I once used on an old truck I had and wanted to install a cruise kit(two magnets on the output yoke of the old SM420 and the pickup coil on a bracket 1/8" away). Then I tried six magnets at the vibration damper: instant controllable fast-idle on a GMC V6.
JM.02
JM.02
Firstgenfanatic
11-08-2009 04:05 PM
Landini1
03-06-2009 07:01 PM
trophystock
07-06-2006 06:28 PM
