Cpl 804
Old Jan 16, 2006 | 02:04 PM
raffshore's Avatar
Cpl 804
Does anyone know if this is a cilinder head for POD or the later injectors. It's an engine from a bus or something with VE wich we are using to put in a boat. Also, I have a P7100, any kits available to replace the VE?
I found a great website qsol2.cummins.com for 50USD you find all the original cummins info you want.
Can someone give me a serial number of a 12V with 7100 pump to do some research?
Thanks,
Raf
Old Jan 16, 2006 | 02:46 PM
G1625S's Avatar
My cpl is 804 also. My serial# suggests a manufacture date sometime in 1987. You most likely have the 9mm injector bores like I do. You can still use POD injectors, you just need adapter sleeves for the tips. They're only 8 bucks a piece, I think.
Good luck on the project!
greg
Old Jan 16, 2006 | 03:04 PM
raffshore's Avatar
On the engine ID there is marked "made in Great Britain" is this good???
Old Jan 16, 2006 | 04:43 PM
ibuiltmine-o1oo's Avatar
i can get into quickserve ( i work for cummins)
heres a 97 esn 56387062
Old Jan 17, 2006 | 02:36 PM
raffshore's Avatar
thanks for the serial.
Any idea's what I have to order to put the in line pump on this engine? I want to make 500HP and I think its going to be easier with the inline pump
Old Jan 17, 2006 | 05:03 PM
Timing case and cover, pump, injection lines and hold-downs, injectors, and the lift pump.
Old Jan 17, 2006 | 05:09 PM
Underpsi's Avatar
Someone told me that if your converting a non ic truck to p-pump then the internal parts are different as well
"camshafts are different
injector tip holes in the head are different size on non-intercooled heads
injector lines are completely different
pistons
whole timing gear case assy
lift pump
and of course any pump brackets"
I didn't think it was that bad
Old Jan 18, 2006 | 02:39 PM
raffshore's Avatar
pistons
lift pump
????? aren't all cpl 804 engines the same?????
Old Jan 18, 2006 | 02:48 PM
All CPL 804 engines would have the same general configuration. CPL 804 would not have an inline pump, which is why a bunch of stuff has to be changed.
The different cam and pistons are a non-issue (the cam profile is a little different, and the rings were moved a little), and there are sleeves to put the late model injectors in the old heads.
Old Jan 18, 2006 | 04:37 PM
raffshore's Avatar
Do the 370 injectors work with the ve?
Old Jan 18, 2006 | 05:05 PM
G1625S's Avatar
Nope. Just get POD's. They have similar flow capabilities.
Alaskanwheeler
Sep 14, 2007 07:06 PM
CTD99
May 16, 2005 10:31 PM
92DIESEL
Feb 22, 2005 04:19 PM
got...DIESEL?
Jan 4, 2005 10:10 AM
George&cheryl
May 7, 2004 12:51 AM
