Coolant leak - pt 2
Coolant leak - pt 2
I think I located my coolant leak. It's a slow drip, but getting worse quickly. It seems to be coming from a plate that's up against the block right behind the oil filter. There are about 7 or 8 bolts that hold the plate on. WHAT IS IT? Is this something that has coolant running through it or am I just seeing a drip that originates somewhere else? Help!
Anything is possible. Wash the engine down at a carwash real good. Confirm exactly where the leak is. If it is coming from the oil cooler. Then remove it and inspect, then replace the gaskets it has. There is a gasket between the block and the cooler, then a gasket between the cooler and cover plate. While its out, you can clean and inspect the oil pressure regulator spring, plunger bore and seat. You do have a service manual right?
Get yourself a little inspection mirror to see under and around things. when your driving the coolant is probably blowing around and some of it evaporating before you see it. It took me 20K miles to finally spot where my HG was leaking from. It was a small seeping leak that used about 1 quart in the 20K. The water pump has a weep hole in the bottom for if the seal goes south. You probably can see either rusty traces or green silica residual where it comming from.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
george7941
Nov 28, 2009 09:28 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
