Converting 1990 Dana 70 to 1995 Dana 70 drums. Possible?
Old Jul 21, 2014 | 08:01 AM
james1's Avatar
Originally Posted by Erska
Ok, I'm still interested to know what does it involve to swap a newer 2nd gen dana 70 drums to the older one if it is possible... I still could do that for the half of the price of the disk conversion...
I understand and I apologize for hijacking this thread. I suspect my question may be related however.
Originally Posted by comotionman
Found that link googling for info of converting from inboard to outboard. Didn't find much. But thought that was interesting and posted it up. Hard to believe nobody has done it. Bearings are the same srw to srw. As are drw to drw. As noted I have compared my drw70 to drw80 and it seems to check out. Have not done it yet though.
I was under the impression, obviously mistaken, that all D70s have inboard brakes, and all D80s have outboard brakes. (That is, I had no idea the Second Gen D70s came with outboard brakes.) I'm not sufficiently familiar with bearing/axle/drum geometry to even offer an opinion. But if it's a plug-and-play modification, I agree that it seems like some one would have tried it?
Old Jul 21, 2014 | 09:01 AM
u2slow's Avatar
With the 2nd gen trucks they changed from ford style brakes to gm style. It might be worth nothing that gm changed the hub bearing spacing when they went to a slide off drum... that would be a key detail to check.
Old Sep 17, 2014 | 08:31 AM
james1's Avatar
Question
Am bumping this thread because the question was never answered.
The guy in Finland who started the thread wants to know if he can take parts from a boneyard Second Gen D70 and use those to convert his First Gen D70 to having outboard brakes?
It's a good question and would be a great BOMB if it's a plug-and-play modification.
Anyone?
TIA.
Old Jan 20, 2016 | 07:30 PM
james1's Avatar
Resurrecting a thread that isn't terribly old because the question is being asked anew.
Converting to outboard brakes is clearly a worthwhile goal.
Old Jan 23, 2016 | 10:58 AM
MrFusion's Avatar
I've been considering the same thing myself. I haven't taken measurements etc but just eyeballing the two D70's it looks like the 1st gen backing plate is situated much further back on the housing tube than the 2nd gen. It appears that you would have to move the backing plates out several inches on the 1st gen D70 to work with 2nd gen drums. There are also the other issues people have brought up. If you compare pictures of the two drums and take into account that the 2nd gen drum is in front of the axle flange and the 1st gen drum is behind the axle flange you will see what I mean.
Probably much easier to swap the complete rear from a 2nd gen under the truck. Remember that a 2nd gen rear is about 6 inches wider at the wheel mounting surface than the 1st gen axle.
Old Dec 16, 2016 | 01:02 PM
samiam4's Avatar
Could you simply shim the backing plate out and move the drum from inboard to outboard on a D70 without complicating going to a newer year?
joem
Jun 22, 2011 07:36 PM
Warlord
Nov 29, 2006 01:57 PM
Fishbait
16
Jan 29, 2006 03:24 PM
Mostwanted
Aug 25, 2004 06:54 AM
TJinTX
Mar 19, 2003 09:10 AM
