Cone Grind Conundrum
Old Feb 7, 2006 | 10:39 PM
mhuppertz's Avatar
I don't think I am ever going to be able to figure out this diesel stuff. So I grind my pin, my truck comes alive, I drive it pretty hard around town all week, and I get 17.84 MPG. Every time I do something on the truck it reacts differently than I expected. How the mileage can go up with the pin grind, maybe that plus the smoke adjustment = better mileage, I dunno. Maybe these engines prefer running at higher RPM's because they run so much leaner than when they are lugged. Maybe when i finally rebuild the overdrive I can drive 90MPH and get 25MPG
Thoughts from the fringe,
Mark
Old Feb 8, 2006 | 12:51 AM
Bushy's Avatar
Patron Saint of 1st gens
Ya tweak the pump/HP you use less throttle to do the same amount of work...gotta luv it don't ya...
bob...
Old Feb 8, 2006 | 03:23 PM
I've found that the POD's respond well to higher RPM when you want fuel economy. I keep 'er in 4th until 50 mph just cruising around (unless I'm trying to be quiet).
Old Feb 8, 2006 | 04:40 PM
mhuppertz's Avatar
Seems counter intuitive doesn't it? Yet there it is, have your cake and eat it too. My truck is now making enough power to hurt itself at will (or is it me hurting it?). I think I need to get the old fellow on the dyno soon, at lease before I break the next weakest part!
Old Feb 9, 2006 | 01:18 AM
Bushy's Avatar
If you can keep your RPM "in the zone" you'll have good mileage and, great performance/response when needed.....
These old girls like to be run in the 1700-1900RPM range while in direct drive (1:1) for auto's that is 3rd gear, for the stick guys, that's 4th gear.
Once you break into the 2000 RPM range you can usually move up a gear and make use of the "overdrive ratio" so to speak.
bob....
Blake Clark
Jul 27, 2012 07:34 PM
Richie O
Feb 22, 2011 11:09 AM
doug
Sep 29, 2003 10:16 PM
drafalske
22
Nov 19, 2002 08:55 PM
