Coil Over on our front end ???
Old Jun 9, 2010 | 10:16 PM
roxxx's Avatar
Has anyone ever done or even seen a coil over front end on our truck.
Plus I was wondering if I extend the springs on the rear (move the mounting point of the springs but not move the axle ) new springs of course. Would the travel and the ride be smoother ? any ideas ?
Old Jun 9, 2010 | 10:24 PM
2wdcumns247's Avatar
springs on the rear? you mean the shocks right? i dont see why you couldnt fab up something for either the front or rear i know someone with a 4link in the rear and half ton gear up front it sits 6inchs off the ground i mean anything is possible but i dont think they make a kit for it. I think it would be a home made deal
Old Jun 9, 2010 | 10:34 PM
torquefan's Avatar
Good idea with the spring mounts- install longer springs for a better ride. Not sure if it's possible though. I do remember an article by Jim Lane about what he did to his rear springs to smooth out the ride on his dually. It's probably worth reading if you can search it out, I'm thinking it was probably a year ago.
Old Jun 10, 2010 | 11:29 AM
roxxx's Avatar
I have a 1 ton 2009 that i am going to measure the springs on to see if there is any length difference .I know the newer truck springs are wider but i plan on using another Dana 80
2wdcumns247 --- Two part question yes I know i ramble longer spring pack in rear hopefully letting the rear axle travel a bit more ,I want to do a 6 inch lift but want the ride to be a tad bit smoother
in the front a coil over system like the newer trucks have
I doubt it will be cost effective but I have patients
Old Jun 10, 2010 | 04:50 PM
Did you happen to look at this thread?
https://www.dieseltruckresource.com/...0-t271209.html
Old Jun 10, 2010 | 05:59 PM
JustRamIt91's Avatar
Yes you can use chevvy springs and move the front mounts forward. I've seen a few guys do this to their 4x4 trucks and it seems to work great.
Old Jun 10, 2010 | 08:33 PM
roxxx's Avatar
Problem is i would have to get it inspected to get insurance They tend to get a little crazy about that kinda frame work the other flat deck that my buddy did it to was a pain
Old Jun 10, 2010 | 10:44 PM
Look at this "how to" its really nicely written up. Shackle flip
You can also use this method with any spring you choose, so long you keep the diff centered in its stock location. Also 4 grade 8 bolts is STRONGER than the stock rivets, shouldn't have a problem passing inspection.
Old Jun 11, 2010 | 12:11 AM
im sry i didnt understand your question i do now tho you are talking about your leaf springs i thought you ment our trucks had coil springs on the rear i was confused that sounds like a cool idea i will talk to some fab people and see if i can come up with an idea
Torque master
0
Oct 25, 2008 11:10 PM
PG4x4
May 17, 2007 01:54 PM
marc03
Oct 8, 2006 11:42 PM
Gordonville
Apr 18, 2005 09:45 AM
bigfoot
Aug 14, 2004 02:22 PM
