Clunking
Clunking
Hello, has anyone experianced a large clunk while turning the wheels at slow speeds or stopped, also happens over some bumps. I can feel it under the cab right under my clutch foot. I have had this for some time now, and keep looking for it but can never find it. It seems to come and go , when it starts happening it will clunk for a week or so then it may be gone for months. Nothing is felt thru the steering wheel when it happens.
Thanks in advance
Thanks in advance
I had a problem with the leaf shackle bushing getting worn and the spring eye would hit the frame rail in some instances. I also had one of the ball joints get loose and slide in the drag link.
Does it make a difference when you hit the brakes? I had the same thing in the pass. side of my truck. Took the wheel off a couple times thinking I would find something. The last time I pulled the caliper off to find everything looked fine. Before I put the caliper back on I cleaned the slide surfaces and greased them up. Put the caliper back on and it's been fine ever since. The caliper was hanging up and not releasing as quick as it should have.
John, I think you may have hit the nail on the head with the shackle bushing, I just havent taken it all apart to see, But I have always thought is was in the leaf spring shakle are as that is directly under my clutch foot. Do you know any part#s for new bushings. I have redone my ball joints and I know its not there, but I can see it could be the same type of clunk, also my calipers are free and sliding well.
I would guess you have a dana 60 front, from previous experience it makes a big difference in ordering parts. I ordered a set of 4 off of JC Whitney they fit the spring eye but not the one in the frame. I ordered a set of moog for the frame but can't recall the part number. If thats the one you need, let me know I'll find the part number for ya.
Thats a sharpe looking truck, almost a spittin image of mine.
hey' guys im the new guy first post bear with me i also have 2wd had same prob and my alinment guy found one of the camber nuts loose and the cam was popping out and back in snug up of all the nuts and no more popping or clunks hope that helps
Welcome greed,
I replaced every part there was on the front of mine, a year or so ago, it did it before and after. I have a friend that has a 92 4x it makes the exact sound. Its almost like someone hitting the firewall with a rubber mallot. It only occors on very rough fields or speed bumps. this has nagged me for 3 years.
Maybe if we can combine our ideas we might figure this one out, its anoying.
few things iv checked, all front end is new, iv used a jack on the tranny to check mounts and on the body itself thinking maybe a body mount had died.
I've looked mine through and through....can't find anything loose or broken anywhere. With my truck i'm almost certain it's the springs making noise... When i oil undercoat it, it changes the sound....Muffles it sort of ?!?
Yes lets combine our ideas I will put mine on the hoist at work maybe tomorrow. If i can get all the dam snow to melt tonight.. Hate working under a truck pooring water everywhere... been listening to this noise for 5 years now was a few more days... By the way My clunk I can actually feel.. more like a sledge hammer hitting the frame for me...
the clunk
well lets see last spring my buddys had a similar sound and we found that the body mount bolt under the driver seat was broke had to try and pull it before we found that it was broke that is about all i can think of for now thanks
