checking tps on 1991 cummins
Old Feb 21, 2009 | 11:51 AM
kit's Avatar
kit
I was trying to check the adjustment on my tps and noticed with center wire going to the to the tps I should have around .6 volts to 1.20 volts but I have 8.0 volts at rest and as I move the throttle to wide open it goes up to 10.0 volts. Am I checking this wrong Or is this the root of my problem??
Old Feb 21, 2009 | 12:18 PM
Where do you have your voltmeter connected? The TPS is a 5 volt circuit. If you go from the purple/white wire to ground you should get 5 volts. If you are getting 12 volts there you have a problem in the wiring (bad hack job by a previous owner?) or a bad 5 volt supply in the PCM.
Black/blue should be a good ground.
Old Feb 21, 2009 | 01:37 PM
kit's Avatar
kit
sorry, I had the meter on a/c but I rechecked and found with a safety pin shoved in the red wire (middle) and plugged into the tps I have 4.2 volts at rest and I open the throttle the voltage stays the same, I read that I should see some change in voltage.
Old Feb 21, 2009 | 01:51 PM
Yes, that voltage should change with throttle position.
Old Feb 21, 2009 | 02:24 PM
kit's Avatar
kit
so does this sound like the tps is bad? or can it be adjusted?
Old Feb 21, 2009 | 02:59 PM
Sounds like it's bad. The voltage should change on the orange/blue wire as the throttle linkage moves.
Old Feb 22, 2009 | 03:19 AM
kit's Avatar
kit
wow that wont be a cheep
Old Feb 22, 2009 | 05:25 AM
RollinCoalSmoke's Avatar
Kit read the how to stickies. If I knew how to bring one of the links up on here I would. Some of the guys have wired in adjustable pots and did away with the expensive tps. The most of them buy the pots at Radio Shack for just a few bucks mount it on the dash. It save you money and gets the tps out of the way of the pump, plus it's adjustable to sum degree. Just read the stickies and you''ll find it. Good luck.
Old Feb 22, 2009 | 10:47 AM
Onemoparnut's Avatar
The pot fix is the best way to go. Does not cost 200 dollars and is adjustable.
whosdunit
May 17, 2014 08:54 AM
hillbillymudrun
Oct 16, 2007 05:25 PM
hemi505
Jun 19, 2006 05:39 PM
Gene Peterson
Jan 24, 2006 05:35 PM
dupp
Feb 24, 2004 06:46 AM
