Check out these injectors
These sound sweet for the price, there 5x14... lil bit bigger then pods and a little bit more exp.
http://www.puredieselpower.com/catal...s-p-12963.html
If these are 435's then these are what zach has... and i like the way his truck performs. These injectors are pretty clean once the turbo spools. I though 435's were smaller then these.
stock 1st gen inj - 6x.009" = .000380" total cross sectional area
2nd gen 215 tips - 4x010 = .000314(17% smaller than stock)
non ic inj - 4x12 = .000452 (19% larger than ic inj)
185's = smaller than stock
190's = smaller than stock
230's = ?
300's = ?
ddp stg III = 50 LPM (liter per minute) 5 hole extrude hone inj
330's - 5x11 = .000474 (20% larger than stock)
2nd gen 370's - 5x12 = .000565 (48% larger than stock)
ddp stg IV = 55 LPM (only 10% larger than stg III's) 5 holes <.013
pods - 4x14 = .000615 (62% larger than stock)
2nd gen 435's - 5x014 = .000769 (twice as large as stock)
custom injectors -
6x13 = .000795
5x15 = .000882
6x14 = .000923
5x16 = .001005
6x15 = .001059
5x17 = .001134 (300% larger than stock)
6x16 = .001206
5x18 = .001272
6x17 = .001360
5x19 = .001416
6x18 = .001526 (400% larger than stock)
5x20 = .001570 (josh ayers custom p-pump inj)
6x20 = .001884 (500% larger than stock)
5x22 = .001900
5x24 = .002261
6x22 = .002280 (600% larger than stock)
However I am very happy with these injectors, they burn cleaner than stock and the power is CRAZY. Just rolling into throttle in 3rd gear I can break both rear tires loose with ease. Shifting into 4th gear hard with alot of throttle it still fishtails all over the place.(on the rare occation the clutch holds. lol)
Are those injectors EDM'd or just extrude honed?
What kind of mods you think you would have to run with them. cause they shere look alot better then gettin pods. if i wouldnt have run a larger turbo i would probly get a set.
You could tune the pump so your stock turbo would work. Just because you have big sticks doen't mean you have to max out the pump. I know when I get sticks I am going to buy fairly big ones so down the road when other upgrades come I have plenty of fuel.
