Cheap 1991.5 21mm H1C Upgrade?
I have a 1991.5 cummins with the massive 21mm housing. It is an automatic truck and takes forever to spool. Most of my driving is on the highway and I usually have a total weight of 15k lbs or so. My main goal is to get better cruising fuel economy and to get it to spool better. I have a HX35 sitting here on a shelf, but it seems that the 12mm housing can choke the engine some with loads at speed.
Just separate the 12cm from the HX and get out your die grinder and start grinding away. You can probably get that 12cm pretty close to a 14cm or you can just try to find a 18cm that someone is getting rid of cheap.
As far as I know the torque converter is stock, with 231,??? on it at this time.Tony
Richie O
Mar 20, 2009 10:07 PM
Firstgenfanatic
Aug 17, 2008 11:25 PM
