Charging issue. HELP!
Old Sep 12, 2009 | 10:55 AM
ktighe's Avatar
Yes, I did have the same codes prior to tach install. I think I read somewhere that the codes should be numericaly sequential but in my case 45 always displays before 41.
I was very careful to not short anything. The tachometer is an inexpensive thing I got on Ebay. Digital RPM TACHOMETER with Built in Warning Light made by Type R
wannadiesel, I want to thank you for your many excellent posts.
1993 W350 DRW Auto, AC
Old Sep 12, 2009 | 12:31 PM
It's not surprising the tach isn't working, most tachs don't like the signal that the PCM puts out.
The codes point to an alternator or wiring harness problem. Check the harness where it runs across the power brake booster and firewall for any chafing. Otherwise it's probably the alternator itself.
The crank sensor is not the problem here.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
jmd4993
Jan 13, 2014 11:21 PM
Onemoparnut
Nov 15, 2011 07:12 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
