A/C...switch to propane?
Old Sep 9, 2009 | 06:27 PM
97catintenn's Avatar
Does anyone use propane in their A/C system? I'm thinking about trying it.
Old Sep 9, 2009 | 06:36 PM
CamperAndy's Avatar
There is a long thread that recently went over this. I will look for it but try to use the search and you should be able to find it.
Old Sep 9, 2009 | 06:41 PM
CamperAndy's Avatar
Found it.
Anyone Running Propane
Old Sep 9, 2009 | 07:52 PM
Thanks Andy, I did search but only came up with people using it as fuel.
Old Sep 9, 2009 | 08:02 PM
CamperAndy's Avatar
When you search use the advanced search and then use the Google search bar. Put in as many keywords as you think will be in a single post and you will get a very concise search.
Old Sep 9, 2009 | 08:07 PM
I was using the search to look through thread topics. I thought that was the best way. I thought that if I search through posts, the keywords would be scattered through different posts, instead of just one.
Old Sep 9, 2009 | 08:26 PM
CamperAndy's Avatar
Try this.
Pick any post that has a lot of words and see if you can find 4 that are seldom used in the same post.
Then use the advanced search function and use the embedded Google search bar and type in those 4 words. You will be surprised how well the search works.
Old Sep 10, 2009 | 03:17 PM
That does work, good! Thanks Andy, google search is so much faster.
Old Sep 10, 2009 | 04:17 PM
BearKiller's Avatar
I have lost my connection to it; but, there is a discussion site that is dedicated to automotive A/C somewhere out there.
When I was researching an A/C problem we were having on some vehicle or other, I ran into and read a number of articles on using Propane as a refrigerant.
Those that had switched over were well pleased with how much cooler their A/C was.
One other point I remember is that, although we are inclined to think of Propane as a dangerous flammable, R-12 and R-134a are equally so, if not more so, especially when pressurized as in an A/C system.
I know absolutely nothing about this, I am just relating what I read.
Old Sep 11, 2009 | 08:48 PM
Thanks for the reply. I've moved forward and am interested in finding the low+high psi now. Currently, I'm at 32/205psi outside temp 75* vent temps 60*
Do I add or remove?
Old Sep 12, 2009 | 01:49 PM
schamran's Avatar
So is propane more dangerous?
Old Sep 12, 2009 | 02:27 PM
From what I have learned...
Auto ignition of propane ~1635°F is ACTUALLY a higher auto ignition than R134a which is 1328°F
There is at least 50% less propane in a charged system than r134a, and 70% less than R12.
MPGs have improved as the compressor is less straining. Helps keep engine temps down, as well.
R134a and r12 will leak out before propane, as propane is a larger molecule. If it does leak out, it gives off an odor like rotten eggs.
edit: vent temps are down in the 40s*f and I don't notice the engine lag like I did with 134a. I still think I have a low charge as the temp should be 10-15 degrees lower than 134a.
Flatbed24v
Jul 31, 2009 10:57 AM
Barryn
Jul 14, 2008 09:30 AM
SPLnut
Dec 31, 2007 11:27 AM
PowerDually
Jun 12, 2005 10:51 AM
redramnc
Mar 28, 2005 06:58 AM
