Runing Cool?
Old Sep 12, 2009 | 09:51 AM
Wettstein's Avatar
Runing Cool?
Got my new rad in and i flushed all the old green stuff out. And now when i am driving the tep barly gits up to normal or never gets up to normal. even after a WOT run on the freeway. After that she cools off to in betweend cold a normal. thanks I just move to Kansas for the Army from Socal.
Old Sep 12, 2009 | 10:15 AM
I'd replace the thermostat.
Old Sep 12, 2009 | 10:19 AM
Wettstein's Avatar
thanks wanna i was also thinkin maybe the fan cluch to. it has never been replaced
Old Sep 12, 2009 | 10:21 AM
Is it locked up? If you can turn the fan easily by hand that's not the problem.
Old Sep 12, 2009 | 10:27 AM
Wettstein's Avatar
No its no locked up but it does not turn freely. it will only turn one fan blade on a hard hard push with my hand.
Old Sep 12, 2009 | 10:30 AM
How about once it gets warmed up? They are sometimes a little stiff when the fluid is cold.
Old Sep 12, 2009 | 10:32 AM
Wettstein's Avatar
No same thing
Old Sep 12, 2009 | 10:38 AM
Take it off and go for a ride.
Old Sep 12, 2009 | 10:40 AM
Wettstein's Avatar
Ok thanks for the help Wannadiesel
Old Sep 12, 2009 | 11:04 AM
93flatbed's Avatar
don't forget "lefty tighty, righty loosy"
Justin
Old Sep 12, 2009 | 11:24 AM
Wettstein's Avatar
thanks
Old Sep 12, 2009 | 02:15 PM
Mike Gallagher's Avatar
If you get a thermostat get it from cummins or atleast an oem type.
Old Sep 12, 2009 | 03:16 PM
BurrisWill's Avatar
what good's taking the fan off do?
Old Sep 12, 2009 | 03:28 PM
93flatbed's Avatar
2 see if t-stat is stuck open or if the fan clutch is stuck on.
If it still runs real cool then the t-stat is more the likley stuck open.
If not then the clutch may be locked up.
Old Sep 12, 2009 | 03:33 PM
BurrisWill's Avatar
Just unscrew the four bolts that hold the little fan assembly ?
