Changed fuel filter!! Sounds like losing fuel!! Need help
Old Sep 17, 2013 | 04:55 PM
j_martin's Avatar
Originally Posted by 209trucker
I filled the new filter to a little over half before putting it on.
The banjo bolt on the outlet line of the filter should have a bleed screw in it. Crack that and pump the fuel pump handle till you get the air out of the filter. If you had done that when you changed the filter, it would have started, stumbled a bit, cleared it's throat, and then run.
Now you must do the above, then bleed at least 3 of the injectors. Might as well do all six. It'll probably start after bleeding 2 or 3. Keep bleeding the rest of them and it'll smooth out. Should only take a few seconds on each. Only caveat is that you didn't get some crud in the fuel line post filter.
Old Sep 21, 2013 | 11:50 PM
209trucker's Avatar
Got er goin again. Thanks for all the help guys, appreciate it
Old Sep 22, 2013 | 11:35 AM
209trucker's Avatar
woodyman
Jul 4, 2012 07:17 PM
Don H
Mar 25, 2009 11:13 PM
pacmule
Sep 5, 2007 08:47 PM
mattzram
Oct 9, 2006 11:38 AM
