Can someone explain the OD/TPS relationship?
Here's where I'm coming from: trucks equipped with the 727 do not have OD and do not have the TPS attachment on top of the VE pump, correct? So, if you were to install a A518 in a truck previously equipped with a 727, how would the OD kick in? How would you wire it to use a POT and not a TPS? Thanks for any info.!
The easiest way to deal with it is to use a pressure switch in the governor pressure test port. Gives you automatic OD operation without having to do all the wiring to install a PCM and make it happy enough to give you OD.
https://www.dieseltruckresource.com/....html?t=156988
A 518 will have a wire harness with two wires coming out of the valve body that controls the OD. one (blue wire) will need a constant 12v source and the other if you wish to control it manually will need to go to a switch that operates off of ground.
calls
May 5, 2004 10:17 AM
dcwm
28
May 14, 2003 02:42 PM
