Cab Roof Light Gaskits
Old Jun 28, 2009 | 11:43 AM
Mike T.'s Avatar
Started sanding my truck for paint but didn't want to pull the running lights off without something to replace the gaskits. Dodge of course dosn't carry them. I finally ended up at Ace and I think they have the perfect stuff. It's solid rubber and it looks like comes in 1/8, 1/16 and 1/32 in thickness. The only draw back is it has a reddish rust color wich I think I can deal with. There was someone on here a while back looking for something like this.
By the way when I took my lights off the rear narrow part of the stock gaskits had shrunk and were letting water in. I saw no rust but is a small hole to look in. Something for you guys to check.
Mike
Old Jun 28, 2009 | 12:36 PM
3738019 Should still be available.
Old Jun 28, 2009 | 02:42 PM
Mike T.'s Avatar
thanks I'll check it out.
Mike
Old Jun 28, 2009 | 04:07 PM
DU.DP.'s Avatar
i just had that same piece up there! trust me you wont like it up there haha! stands out! so i went and got a sheet of thin rubber and made mine a little bit oversized and siliconed them up.
Old Jun 29, 2009 | 12:49 PM
Mike T.'s Avatar
I checked no dealerships have them in stock.
DUDP
They are an ugly color
Old Jun 29, 2009 | 04:29 PM
rustbucket's Avatar
I just used clear silicone. When I got the 93, all of the lights were leaking, because the stock gasket had shrunk. I put a bead around the bottom edge of each light, and let it cure for a while, then screwed them down, so far no leaks, in nearly four years. If you let the silicone cure some before mounting, there isn't as much of a problem with the light sticking to the roof, and makes changeing the bulb a lot easier.
Old Jun 29, 2009 | 07:10 PM
Mike T.'s Avatar
Thanks Rustbucket
Old Jul 7, 2009 | 01:36 PM
raggmann's Avatar
I had issues with my cab light gaskets as well.Yep,no dealers have them.
I ended up going to a dollar store and bought a few computer mouse pads.I cut the material approx 1/8-3/16" bigger than the lights.
So far so good,no leaks.
Roperteacher
Nov 16, 2007 10:13 AM
Rancho71
Jan 27, 2005 08:41 AM
Rancho71
100
Dec 17, 2004 09:07 PM
