a/c help
Old Aug 10, 2010 | 07:25 PM
deanhinsley1963's Avatar
Question a/c help
ok guys when driving down the road my a/c is good around 40deg. But when idling at lights or store it gets to blowing about 60deg. I'm thinking of putting a elect. fan in front of the rad behind the grille,does anyone know if there is room? I will retain the stock clutch fan and put the elect. on a switch. Think this will help? THANKS
Old Aug 10, 2010 | 07:37 PM
did you clean out your HVAC box?
http://ramchargercentral.com/index.p...iew;article=57
Almost sounds like maybe your clutch fan isn't working?
Our 93 has great R-12 A/C and it only goes up about 5* idling or at a stop light.
Old Aug 10, 2010 | 08:56 PM
dieselJon's Avatar
I wish I got 60*...
Old Aug 10, 2010 | 09:21 PM
Onemoparnut's Avatar
On an intercooled truck there is no room for a fan behind the grille. I would suspect the fan clutch like crossys son said.
Old Aug 10, 2010 | 09:31 PM
Also, his condenser could be like yours was, Bill.
The fins came unstuck from the tubes so it only gave good A/C with a lot of airflow.
Old Aug 11, 2010 | 05:18 AM
Jim Lane's Avatar
I installed my 2 electric fans to get ram air for just the same reason however being intercooled you will be limited in space behind the grille.
https://www.dieseltruckresource.com/...s-t250585.html
How is your refrigerant charge?
Is your hot water shutoff valve working?
Also check your idle speed, it could be a bit low a fast idle solenoid would help turning your compressor fast enough.
You could mount a remote condenser under the truck with fans and a shroud and eliminate the front condenser all together, I have built a few systems using this idea.
I would install a High Pressure cutout switch in-case the fan failed to keep your system from going nuclear.
http://www.nostalgicairparts.com/air...-shroud-33.php
When I used to work on Transit Busses I noticed that very few of the air conditioning systems had the condenser cooled by the engine fan, they were either electric or hydraulic driven fans.
You can even get a 12-volt hermetic compressor that doesn't require the engine to be running.
Here you could install a chill plate in your cab and turn it into a refrigerated cab.
http://www.seafrost.com/bd.htm
Just some ideas.
Jim
Old Aug 11, 2010 | 09:37 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I know you all are talking about earlier modles than mine but I have the exact same issue. Crusing is >40F and when I come off the freeway or drive around town it's barely in the mid 50's sometimes in the 60's and the fan runs just not like I think it should. I wanted to put a seperate switch on the fan to control when it's on manually but haven't got around to investigating how to do it on the '03's. My systemis charged, all evap areas are clean and the cores up front are all spotless as well. My older 82 GMC had freezing cold air even at an idle and this thing doesn't do that good out running. Wonder why Chrysler/Dodge couldn't come up with a better idea for this cool thing. Maybe it has a LOT to do with the switch from R12 to R134.
Old Aug 11, 2010 | 10:01 AM
lenuelmp23's Avatar
Mine does the opisit. When I am going 70 at high rpm mine does not blow as cold as at an idle. Charge is good converted to r34 this summer
Old Aug 11, 2010 | 05:23 PM
yes I have cleaned out the hvac box. Is there any way to test the fan clutch? I turned it by hand and it has resistance it does'nt just spin in other words. On a hot day going down the road you can hear the fan come on and off it's pretty loud. any ideas THANKS GUYS
Old Aug 11, 2010 | 07:17 PM
Sounds like your fan clutch works. Check that condenser.
Old Aug 12, 2010 | 05:45 PM
ok,Thanks Faith.
Old Aug 12, 2010 | 09:57 PM
d22019's Avatar
I had the same battle with my a/c at the beginning of summer. It turned out that the area between the intercooler and the radiator was packed with grass and mud.I used compressed air to clean it out and washed everything down with simple green.I can get down to 38f idling now.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
