Brake Question
Old Oct 26, 2006 | 05:19 PM
tallzag's Avatar
Brake Question
On my 92 250 2WD when I sit at a light for a while with the brake pedal pushed in the E-Brake and Anti-Lock brake lights on the dash light up. They go away right away when I accelerate from the light, any idea what could cause this? Everything else seems OK, think my front rotors are a little warped, but the ABS works. I do have a little brake creep as well, might be time for a new master cylinder. Everything is original on the truck and it has 72k miles. Just drove it from Seattle to LA and back and it did great!
Old Oct 26, 2006 | 07:16 PM
Sounds like a leak in the hydraulic system. Are you losing brake fluid anywhere?
Old Oct 26, 2006 | 07:27 PM
tallzag's Avatar
Just checked the Master Cylinder and the front reservoir was way low, looks like the rear cylinders might be leaking. Hmmm...maybe time for some rear disc brakes
Old Feb 5, 2007 | 08:41 PM
DaleK's Avatar
Question Brake Question (where is the dash light?)
My E-Brake light does not come on when the key is in the "ON" position. It never has since I owned the truck (1 year). I suspect that the bulb is the problem, could you please telll me where on the dash the light is located?
I have a 91 Dodge W-250 4WD.
Thanks
Dale
Old Feb 5, 2007 | 09:01 PM
loch's Avatar
its in the diesel message center to the right. just pull dash and replace the bulb. I believe its at the top directly above the antilock.
Old Feb 6, 2007 | 08:49 AM
Ace's Avatar
Ace
I have the same symptom and I'm led to believe it is the low vacuum warnining sensor. I've checked everything else I can find including all the vacuum lines, brake resevoir, possible leaks, etc. Brake pedal is firm, brakes no prob. Dash light just likes to come on while sitting at stopligts.
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
ddestruel
Apr 6, 2005 11:26 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
