brake problems need help
Old Feb 20, 2008 | 05:32 PM
darkale69's Avatar
well brakes are the same but i readjusted the the shoes, when i did them the first time i did them till they scrubed this time i did em tell they locked and then backed them off. i ordered the rwal valve should be here by friday.
Old Feb 20, 2008 | 05:53 PM
hoyt79's Avatar
sounds like it could be the rear wheel antilock brake computer ... as i understand it controls a pressure bleeder (like proportional valve) if it screws up can cause all sorts of wierd problems.... my 91 gas pot had similiar problems as you have explained... it was replaced and my brakes signifigantly improved ...... is you abs or brake light on??
Old Feb 20, 2008 | 06:12 PM
darkale69's Avatar
no thats the wierd thing, hasn't sent off a light yet for low vacuum either.
Old Feb 20, 2008 | 06:25 PM
hoyt79's Avatar
i cant remember if my warning lights came on or not .. i think the rwal computer was only $150 or so canadian when i bought a few years ago....
an adjustable proportioning valve would be the way to go if you had the time money and patience/knowhow too install and setup.....
good luck
Old Feb 21, 2008 | 06:04 AM
jogl's Avatar
Just want to second what Farmer0_1 said about blocking lines and checking. The best brake trouble shooting tool I have is the brake line plug(s) that I made by kinking over some brake line and soldering it shut. Makes isolating a brake problem go pretty quick.
As mentioned start by blocking off both the primary and secondary ports on the master and see what happens. If the master and booster are ok your pedal should hardly move and be almost rock solid.
Then just work your way out.
Brake problems can be such a chore.
Good Day,
JP.
Old Feb 23, 2008 | 08:15 PM
darkale69's Avatar
well i don't know if its the vacuum pump cause i hooked a vac. gauge to it and it read 24 at idle which is real high??? changed the rear abs but haven't tested it yet but something tells me its the propotioning valve.where can i get one other than the dealer or is there a better alternative.
Old Feb 24, 2008 | 05:27 PM
The vacuum pump is fine.
Old Feb 25, 2008 | 12:41 PM
darkale69's Avatar
as it was said before but i was too hard headed to listen it was the rwal got it changed and i brakes like a totally different machine. i have to relearn how to brake in it now about smack my head into the steering wheel if im not careful.
thanx for all your input ill listen faster next time.
dieselluvr
Dec 29, 2013 11:02 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
archer39
Nov 22, 2009 04:53 PM
Diesel Junkie
Dec 27, 2007 08:24 PM
SilverHoss99
Dec 12, 2006 09:40 PM
