Brake pedal drops
The caliper slides on these trucks are very vulnerable to rust. The surfaces need to be clean, flat, and lubed with anti-seize or high-temp brake grease. Ideally they should be cleaned up every 6 months or so.
4x4: https://www.dieseltruckresource.com/...d.php?t=143024
2wd: https://www.dieseltruckresource.com/...-t248986.html?
i replaced my brake hoses last year. i thought i was carefull but i guess i could have damaged one in the process.
ive cleaned the rails and reapplied anti-seize.
the fsm says the outer pad shouldnt have any free play between it and the caliper. mine seems to have a considerable amount. could this cause my problem?
also, in the fsm, and that sticky, it shows only one support spring. My truck had 2 springs. one on each side of the support key. my new caliper only has 1
Should i have one or 2?
Ive read that If its a bad hose,you should loosen the bleeder and fluid will spurt out then the wheel will spin free. But mine doesn't spurt, it just runs out a little and it also doesn't free up the wheel.
is there a test to determine if a caliper is bad?
the shop said the one they sold me was probly bad and gave me another one, but the chances of that seem slim. so i just wanna make sure its my caliper for sure. because as soon as i put fluid in this new caliper i cant return it.
Also does anybody know why my truck has 2 support springs, yet the new caliper only has one?
reaves11
Feb 10, 2013 02:29 PM
GearHd6
36
Oct 26, 2010 07:34 AM
600 Megawatts
Mar 26, 2008 07:09 PM
