brake boost and brake pedal
Old Jul 2, 2009 | 12:21 AM
Diesel Jeff's Avatar
Aloha My 1st Gen Buds!
I just changed my brake booster on my truck. I adjusted the piston to match exactly the length of the booster I replaced.
I have a problem with the brake pedal not coming back all the time, and my brake light won't shut off when it happens.
I tested it while idling and laying down right near the pedal to watch what it is doing. If I pump the brakes, the pedal returns no problem, but when I give it throttle, i notice the brake pedal slowly moving in and releasing the brake light switch. If I pump them again, it firms up and returns back fine again.
I didn't have this pedal problem before I replaced the brake booster. I had to replace the booster because it was hissing loudly, and I had to press really hard to get the brakes to work. With the new booster the brakes work effortlessly, but I have this issue with the pedal.
Could there be a problem with the new booster (Cardone rebuilt)?
Could air in the lines cause this?
Could my master cylinder be bad?
Again, it won't do it if I pump the brakes a bit, but then it loosens up under throttle. I put a bungie cord tied to the brake pedal to retrieve the pedal in the mean time.
Please help.
Jeff
Old Jul 2, 2009 | 05:18 PM
I'd get another booster.
Old Jul 3, 2009 | 10:57 AM
cougar's Avatar
Sounds like an internal leak in the booster. It should not pull the brake pedal down when you rev it.
Old Jul 3, 2009 | 07:30 PM
RollinCoalSmoke's Avatar
On my 4th booster and have very similar problems. No vacuum leaks no hissing ect. The last 3 were complete with a master cylinder. I pulled the m/c to see if it was adjusted correctly and they were all very close. Now the pedal almost goes to the floor. It's like on a daily basis it gets worse. I'm to the point of finding a hydravac system so i'll have brake at least good enough to stop the truck. If someone has a cure i'll sure listen. Good luck Diesel Jeff.
Old Jul 5, 2009 | 04:46 PM
jogl's Avatar
A quick and easy thing to try is just turn the adjuster screw on the booster (the one that goes into the master and works the cylinder) out a few turns.
Worked for me and you only need to take off two nuts and put them back on.
JP.
Old Jul 5, 2009 | 05:56 PM
Machinos's Avatar
Maybe the check valve isn't working right?
reaves11
Feb 10, 2013 02:29 PM
600 Megawatts
Mar 26, 2008 07:09 PM
GIT-R-DONE
Mar 4, 2007 01:34 PM
coyote54
Jan 1, 2007 05:58 PM
