Brake failure
Old Jul 10, 2011 | 07:23 PM
bannerd's Avatar
Brake failure
Hey all, my brake booster is leaking in the back (filled with fluid) and it's leaking from the master cylinder. I was looking for a new booster and master cylinder, I'm finding there is a 1inch and 3/4" sizes? What one should I get? This is a 91 W250 with a 4500 front end (dana 60).
just my luck
Old Jul 11, 2011 | 06:17 AM
Neither, it's 1 1/8".
Old Jul 11, 2011 | 06:57 AM
bannerd's Avatar
Anyone have a link or partnumber? The check valve is 3/4" and 1" is what I was talking about. It looks like what I have, I was planning to get rear disc brakes at some point so I don't know if I should go with a universal setup or stick with the stock.
Old Jul 11, 2011 | 09:59 AM
bannerd's Avatar
I think I have a 3/4" check valve, will have to look tonight.
This looks like a good deal, although I never heard of cardone before
http://shop.advanceautoparts.com/web...___#fragment-2
Good brand?
Old Jul 11, 2011 | 06:28 PM
Cardone is garbage. Hate all their products, Used them all with horrbile results. LOL.
I usually buy Bendix or good name brand stuff off rockauto.com and just wait for it to get here.
Old Jul 11, 2011 | 07:03 PM
bannerd's Avatar
Yeah, I might go with the centric brand, they make good stuff and are a branch from stoptech.
Old Jul 12, 2011 | 07:16 AM
454 no more's Avatar
I wouldnt cheap out on parts! I installed two rebuilt masters, and got two bad ones in a row. Finally put in a new one and the brakes are as good as they've ever been.
Old Jul 13, 2011 | 11:38 AM
bannerd's Avatar
Bumping this back up, I'm having a hard time finding a brake booster. They're all A1-cardone crap.. I did find a few centric boosters but they have many different numbers. The only difference I can tell is the check valve is bigger. What does the check valve do? Would a 1inch give better performance to a 3/4"?
Old Jul 13, 2011 | 11:43 AM
maybe368's Avatar
i am pretty sure A1Cardone is the only one re-manufacturing the boosters and A-lock valves. I cannot find anyone else...Mark
Old Jul 13, 2011 | 11:48 AM
bannerd's Avatar
If you scroll down here; There are a bunch of centric's
http://www.drivewire.com/vehicle/199...brake-booster/
I've been using Centric rotors/pads for awhile and they're really nice! Although I don't know what one to get.
Old Jul 13, 2011 | 11:53 AM
maybe368's Avatar
Cool, I don't think the size of the check valve really matters. I have had bad luck with A1Cardone so I will try one of these next time. Do they make mated units?...Mark
Old Jul 13, 2011 | 11:55 AM
bannerd's Avatar
Just got off the phone with them. This is how it works.. you pull the brake booster out and on that push rod there is a code on it. Keep in mind that if the brake booster is not stock this might not work
Rod Code(s)
13849
14177
Centric Part# - 160.80.244
Rod Code(s)
13851
14180
Centric Part# -160.80.245
Rode Code 1"
14180
Centric Part# -160.80.250
If the rod code matches the above, then the booster you need is the part number below. Awesome! Looks like I have some work to do haha
Also this was for a 91 W250 but apparently those codes are what was used on the assembly line. They will work with a D250 as well as long as it's 1st gen series. If the code is different, give them a call (626.961.5775)
Old Jul 13, 2011 | 12:10 PM
maybe368's Avatar
Here Here
is the centric MC...looks new...Mark
Old Jul 13, 2011 | 12:15 PM
bannerd's Avatar
Sweet! I should be ready to rock once I find out what booster I have. I'll let you all know how it brakes!
Old Jul 13, 2011 | 12:31 PM
maybe368's Avatar
Cool. I'll be right behind you...Mark
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
wild4stangs
Jul 13, 2006 08:59 PM
piperca
Apr 9, 2005 08:35 PM
