Brake cylinder size?
If you intend to do the job correctly, then you must ALSO replace the nylock nut, as per the FSM they're desiged to be used only once, then thrown out. This is why freight train suggested using something different, as a good number of us already have.
Have fun, either way
Dorman Products - 05306
They should be here Wednesday from Amazon.
Edwin
That's what I plan to do which is why I cross referenced the part number that freight train gave me to a Dorman part which is 2 nuts and a bendable locking washer.
Edwin
Edwin
That's the setup I bought, and It works well. I ordered a bunch of those extra washers from Rockauto (see below) to keep in stock as they're the only part that goes bad. I like the other style much better, which if I ever replace I would order from partsmike previously shown.
Sometimes during disassembly, the washer tab that's bent over snaps off, so that's why I keep a bunch in stock. Bought the kit back in september of 2012, had the truck apart 5-6 times since then, and reused only one extra tabbed washer. Much less expensive in the long run, and a more confident setup. You'll be much happier with it than that nylock nut and wedge junk that the OEM was.
I think I paid $.99 each
https://www.rockauto.com/en/moreinfo.php?pk=15784&jsn=1
I also keep the axle gaskets in stock as well. Rock auto might be cheaper though
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Journier
Nov 22, 2004 02:56 PM
