Bosch 190 injectors and timing
Old Oct 25, 2010 | 09:43 AM
Subliminal's Avatar
Hello!
I think I've finally chased down the vibration in my engine enough to give a little goose to the power.
I have Bosch 190 injectors from PDR. They recommended using the thinnest washers, which I did.
I'd like to know if anyone knows if these require more timing than stock, or if they act just like stock?
Basically, I searched and couldn't find anything on timing and Bosch 190s.
Old Oct 25, 2010 | 10:19 AM
roxxx's Avatar
Unless they put different nozzles on,
they should be fine. unless your timing is off and was off before you installed the new injectors ?
Not sure if you have seen this or not
http://www.1stgen.org/viewtopic.php?f=4&t=1363
Old Oct 25, 2010 | 11:08 AM
cougar's Avatar
The 190's from what I've read have the same operating or "POP" pressure so your base timing should be good.
Old Oct 26, 2010 | 03:09 PM
nascar mark's Avatar
our 190's are stock Bosch inj's and nozzles. I do recommend bumping the timing for the added fuel that the inj's put out. Every engine is different but a good base to go with is 1/8" between the lines will lesson smoke, lower egt's and give you slightly better fuel economy.
Old Oct 26, 2010 | 10:21 PM
IRoss's Avatar
I found with the 190's that anything over 17 degrees(ish), set with the dial indictator would slightly lower economy...
Old Oct 27, 2010 | 07:24 AM
Subliminal's Avatar
Roughly how many degrees is stock and how many for an 1/8" bump?
I don't have a dial indicator.
Thanks for the replies, guys!
Old Oct 27, 2010 | 11:50 AM
Some engines like more timing then others. All comes down to how much you crank the power screw.
Approx 14 deg's is stock on the intercooled engines. No need to use a dial indicator, adjust til it feels right for your engine.
1/8" bump is approx 2.5 deg's.
Old Oct 27, 2010 | 12:00 PM
Subliminal's Avatar
Mark,
Thanks for the answers!
I bumped the timing and turned the fuel screw a bit for good luck. Definitely more power on tap...and definitely more black smoke. Not sure if there's too much black smoke at the moment...might end up backing the fuel out a tad.
Old Oct 27, 2010 | 12:11 PM
Tighten up on the star wheel for best results.
Old Oct 27, 2010 | 12:20 PM
Subliminal's Avatar
I'll give it a shot, but I have one more stupid question:
Tightening up the starwheel is counter clockwise, correct?
Old Oct 27, 2010 | 03:45 PM
Yes.
Old Oct 27, 2010 | 04:16 PM
Subliminal's Avatar
Thanks!
Old Oct 27, 2010 | 07:00 PM
BC847's Avatar
1st Generation Admin
Looking back through earlier posts, I found 1.85mm (stock is 1.4mm) lift was a good number for my 190s running the thinest washers available (.20"?). Tweaking the Star-Wheel cleaned up the low boost smoke.
(If you do get a dial gauge set-up)
Old Oct 28, 2010 | 08:09 AM
Subliminal's Avatar
Thanks, David!
d22019
Feb 12, 2013 07:50 PM
The_Head
Nov 30, 2008 11:53 AM
Boatnik
Feb 20, 2007 04:19 PM
Jim5870
Jul 15, 2006 01:32 AM
