Boost at speed?
Old Jul 17, 2008 | 10:36 PM
deerslayer1979's Avatar
Boost at speed?
I took the Cummins to work today, to try and get the clutch to release correctly, and noticed that when I am going about 65-70 mph I was making about 5psi of boost. I was on Interstate 90 in the river valley, so it was fairly flat, and it was holding right at 5psi and would jump up a couple psi when I would hit a hill. I had the cruise on so I know it wasn't because my foot was in and out of the throttle. Is this normal? I figured once I was up to speed I shouldn't make any boost, since boost means the motor is fueling and with 4.10's and a 5spd I shouldn't have any problems with torque in the top "hole".
DS79
Old Jul 17, 2008 | 10:41 PM
daking's Avatar
im around 10 pounds at 65
Old Jul 17, 2008 | 10:45 PM
stackx2's Avatar
im running about 10 -12 psi at 65. 5 sounds right for your mods
Old Jul 17, 2008 | 11:13 PM
Montana2x2's Avatar
On flat ground with 3:54 I run about 3psi at that speed.
Old Jul 17, 2008 | 11:28 PM
Ok, so my milage just sucks that bad then. That sucks, was hoping I could do something to make it better. So, once I do the 16cm housing, and the 3200 spring I should see even more?
DS79
Old Jul 17, 2008 | 11:33 PM
IRoss's Avatar
You can raise the starwheel to decrease the fueling at your cruising boost levels, which should result in better mileage....there is a chart around which shows the amount of boost needed to start deflection of the afc spring vs. starwheel height...try the search
Old Jul 18, 2008 | 06:37 AM
SmokemS's Avatar
i'm about 4psi at 65 mph with my 3.55's
Old Jul 18, 2008 | 09:06 AM
MoparMarv's Avatar
4-5psi @70mph in my truck. about 10-12psi when going up hill or accelerating.
Old Jul 18, 2008 | 05:50 PM
DS79
The governor tries to keep the engine at a fairly constant speed, so when you hit a small grade change the governor will add some fuel even if you don't push the pedal down.
Old Jul 18, 2008 | 07:30 PM
Sounds good, guess I was thinking I shouldn't see any once I' up to speed. Guess I was wrong. I think the AFC has to see 10psi before it starts to add fuel, I remember reading that somewhere. My star wheel is only turned down about 1/4 turn so that shouldn't be an issue. I need to get my speedo accurate before I get to worked up over milage I guess.
DS79
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
