5 speed to 6 speed..... Change-out
Old Feb 15, 2004 | 09:56 AM
Sonny's Avatar
I was curious what was involved in changing out a 99 5-speed (in 1994 12v) to the newer 5400 6- speed? Thanks , sonny
Old Feb 15, 2004 | 09:58 AM
Junk Yard Dog's Avatar
The clutch and flywheel, along with shorter rear drive shaft, and longer front shaft
Oh, and don't forget the little button in the end of the shifter......It has an extra number
Rick
Old Feb 15, 2004 | 02:23 PM
Haulin_in_Dixie's Avatar
You have a couple of options for the clutch, SBC has a convert clutch that uses the same flywheel or has a redrilled flywheel to mount the larger clutch. I used the latter.
The stick portion of the nv4500 will fit but the actual shifter bolted to the transmission with four bolts will not. The rear mount will be in the wrong place with the right crossmember. A 1/4 steel plate about 6 x 8 with the proper holes drilled will mount it up.
My drive shafts were modified 6 inches, where I usually see 5 1/2 listed as the length. The shifter link for the transfer case will have to be cut and lengthened the six inches.
I never got the exhaust bracket at the rear mount to line up so did not put it on. I have never had a problem with it, I have a straight pipe.
The backup light wiring is in a different place but will mount up with no changes.
Old Feb 15, 2004 | 11:47 PM
Roger rodbolt's Avatar
If you are converting a 2 wheel drive truck, the Dodge 6 speed has no provision for speedometer drive. You can swap in a '98 or later crossmember if available or make a mount as Haulin' said.
peanut
Mar 24, 2010 10:32 PM
dodgebowhunter
Jun 29, 2009 08:59 AM
jmccart
13
May 27, 2009 09:45 PM
markm4
Jul 29, 2007 11:16 AM
doitl8r
Jun 4, 2004 11:14 AM
