Boost gauge is stuck
My autometer boost gauge is stuck on 17psi. i can suck it down but it goes right back up. i can blow it up to 35 but sticks on 17. whats up with this thing.
Got moisture in the gauge and when the temperture got below freezing , the moisture become frozen, pushing the the needle on around and it will not return back to zero. The gauge is sealed, time to buy a new one. I have one to do this.
The inside of his cab got below freezing?
If you over pressurize a gauge it can cause the spur gear that drives the needle to jump a tooth or two on the sector gear that is connected to the Bourdon Tube and cause the needle to rest anywhere on the dial.
http://en.wikipedia.org/wiki/Bourdon_tube#Bourdon
Sometimes if the gauge is rapidly cycled it can also cause this.
This is why Fuel Pressure gauges will become inaccurate after a while when the internal mechanism is hammered from the pulsations from the lift pump.
Even with a snubber the pulsations are not removed just minimized.
It will help to install a Pulsation Damper, a section of rubber hose with one end capped off somewhere in the line.
Wow, don’t know if any of this information will help you, it just came off the top of my head.
How old is the gauge?
Have you tried to contact Auto Meter before you try and take it apart?
Maybe they will replace it under warranty.
Jim
Oh wait, thats bourdon...I guess the damper concept is the same as in home plumbing for water hammering huh? I can see the need for it in a fluid system but didn't realize the same need in air. I thought the pocket of air in a liquid system is what dampened the problem? But you're saying that an extra air "pocket" in an air system will work just as well?
BTW, pretty cool wiki on how a guage works!
Maybe he was sucking on the bourbon tube and it just seemed stuck???
It is not just the extra volume of air that is compressing but the rubber hose is also absorbing the pulses.
In a potable water system you can solder a vertical section of pipe capped on the top to create a cushion of air space.
Water Hammer is when the flowing water suddenly stops when the valve is closed; the water is still flowing and hits the dead end creating a shockwave.
This should make your head hurt.
http://rds.yahoo.com/_ylt=A0oGkm_XRF...i/Water_hammer
They also sell a snubber that has a sliding piston of a Bootstrap design that separates the water from an opposing charge of air or nitrogen.
Any opposing charge has to correspond to the working charge of the system usually just a dead air space is sufficient.
Also it is not simply air in the line the fluid line needs to be completely full of fluid with no air then tee off the line into the air charged snubber, air in the line will actually cause inaccurate readings.
Jim
Maybe it is just me but I found this very interesting.
http://en.wikipedia.org/wiki/Water_tower
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
CRXsi
Mar 31, 2006 07:56 AM
