Boost Gauge
On my 2nd gen, I purchased a boost bolt from the DTR store. It's a drilled out bolt that simply replaces one of the bolts on the intake plate and allows for a 1/8 NPT fitting to be threaded into the head of it. Very simple to install, no drilling or thread tapping required.
There is a pipe plug under the intake elbow in the side of the head. You can install your boost tube fitting here. You will have to drill a hole in your throttle bellcrank bracket to run your boost line.
I used this one on my 89 motor. I did not have to drill out my bracket. It's a tight squeeze but works fine.
Performance & Accessories Bully Dog Triple Dog 40500 w/Crazy Larry, Outlook, boost gauge, pillar mount, boost f
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
CRXsi
Mar 31, 2006 07:56 AM
