Boost gauge
Old Sep 3, 2009 | 03:25 PM
sodbuster's Avatar
Boost gauge
Picked up a boost gauge today where do I plum it in 1990 noni/c
Old Sep 3, 2009 | 03:28 PM
jimbo486's Avatar
behind the throttle bracket in the side of the head/intake manifold you'll find a plug just in front of the air intake temperature sensor. for the non i/c'd motors, you'll have to drill a hole in the throttle bracket to access it easier when installing the copper or nylon line.
Old Sep 3, 2009 | 04:20 PM
Right here, I used a hole saw to cut it, on a battery drill on low speed. BE CAREFUL, there is fuel lines behind the bracket. Then I found an o-ring that just so happened to be perfect size and put it into the hole i drilled so the boost line doesn't get cut on the edge of the hole. Lining it up is kinda hard but you'll get it..
Works good.
Old Sep 4, 2009 | 03:53 AM
sodbuster's Avatar
Thanks guys
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
